Fuel Filters D4 1951
1 year 9 months ago #245072 by molacr
Fuel Filters D4 1951 was created by molacr
I have a  lots of rust in the Diesel Tank of My 1951 D4. I am planning to put on a outside tank filter. I need to change the fuel filters. It takes 4.. I have 2 D4s. I am looking for 8 filters.. Where can I buy these? Thank You
1 year 9 months ago - 1 year 9 months ago #245076 by D4Jim
Replied by D4Jim on topic Fuel Filters D4 1951
The original part number from Cat for the set was 7B8264 and I got my last set at NAPA. This is the original "sock" type. About any supply house can cross reference to them as there are several places that still can get them. Good luck on keeping the fuel clean as that is an absolute necessity. Don't remember the NAPA #.
PS:  Seat or side tank?
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Last edit: 1 year 9 months ago by D4Jim.
1 year 9 months ago #245083 by trainzkid88
Replied by trainzkid88 on topic Fuel Filters D4 1951
the dealers still have both types. the second is spiral wound cord.
1 year 9 months ago #245085 by rax200
Replied by rax200 on topic Fuel Filters D4 1951
Hi molar,
The part number for the filters is 2A5886 x4 and you will need 2 x 7b7635 as that group number is not used now.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
The following user(s) said Thank You: molacr
1 year 9 months ago #245098 by molacr
Replied by molacr on topic Fuel Filters D4 1951
Both D4s have seat tanks. One is clean the other sat outside 3 yrs and developed lots OF RUST. i DON'T know for sure how to clean it. Do the best I can and install remote filter back by tank outlet. Its real bad plugs filters in a few hrs time.
1 year 9 months ago #245104 by trainzkid88
do you have a mate with a steam boiler? if so remove the tank drain it and have it steam blasted. the other way is get some dog chain or a couple of handfuls of small steel nuts say 3/8 to 5/8 and chuck them in the tank with some alkaline degreaser or cleaning vinegar and roll the thing all round the yard make sure every side is well agitated. drain and repeat a few times, remove the nuts/chain then rinse with hot soapy water and let dry in the sun having a heat gun or hair dryer blowing into it will speed the dry and get it properly dry.
depends how bad it is but it might be worth treating the tank with fuel tank sealer such as red-kote or the por15 u.s standard tank sealer or a similar product.
The following user(s) said Thank You: Shaban1983
1 year 9 months ago #245115 by seyser
Replied by seyser on topic Fuel Filters D4 1951
Might be worth installing a different tank if its real bad. I see your in MN too. There is a guy in Harmony who parts out these machines and might have a replacement if you decide to go that route.
1 year 9 months ago - 1 year 9 months ago #245150 by Shaban1983
Replied by Shaban1983 on topic Fuel Filters D4 1951
I've heard of people rigging the tank up with chanins/bolts/gravel iniside to a rear tractor tyre and driving around doing chores for a day.
Take off and drain/refill with clean diesel/reposition a few times. That's supposed to dislodge whatever rust is inside there.
Last edit: 1 year 9 months ago by Shaban1983.
1 year 9 months ago #245151 by trainzkid88
thats the less labour intensive method. and it works well with square or rectangle tanks. you do need to turn it part way through so you get all sides.
1 year 9 months ago #245152 by rax200
I have also heard that people have rigged them up a cement mixer and let it go for the day, with nuts, bolts, chain or gravel then cleaned them out and walla loverly and clean.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
