1936 cat 22
1936 cat 22
racin j
Send a private message to racin j
Runs alittle rough at times but hopfully with some work it will pure like a kitten!
Sun, Sep 28, 2008 10:18 AM
Peter Mercer
Send a private message to Peter Mercer
Great looking Cat. How about some more pics of the blade and pto hydraulic pump set up.
Peter Mercer
1934 Caterpillar 22 - 2F818,
1952 Willy's M38 Jeep, 1956 Farmall Cub, 1961 GMC Pick-up, 1964 Thunderbird.
St. John's, Newfoundland
Canada
Tue, Sep 30, 2008 3:07 AM
racin j
Reply to Peter Mercer:
Will this do?
Wed, Oct 1, 2008 4:33 AM
Reply to racin j:
Will this do?
But tell her she is prettier than the tractor!
Or she won't let you play with it anymore!
Wed, Oct 1, 2008 7:07 PM
bgates
Send a private message to bgates
Reply to drujinin:
To make it run smoother, try adjusting and cleaning the points in the magneto, clean or replace the sparkplugs ($3.00 each at Car Quest), run aviation gas through it if you have varnish issues, retorque the head, adjust the valves, then hook onto something heavy and run the crap out of it. I couldn't get the temperature of the engine up so I put a towel over the radiator when I ran it hard, and that alone solved a lot of problems. These engines want to work hard and they don't like a lot of ideling. I did all of the above and mine runs sweet.
Now-- I have to find an operator that looks that good and I'll be set.
Thu, Oct 2, 2008 12:51 PM
racin j
Reply to bgates:
Took the magneto off to get it redone and the guy said the coil was bad so that should make a big difference when we get it back together!
Fri, Oct 3, 2008 5:44 AM
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
