Hello everyone, I have a problem with my throttle on my d2 5U 13773.
1 year 10 months ago #244568 by smokiejoe70
The governor locking control on the side of the diesel engine won't  stay in position. When I  throttle up it just goes back to idol. Has anyone had this problem and fixed it. Some input would be appreciated.  Thank you.
1 year 10 months ago #244574 by dpendzic
the pawls have worn that lock the throttle in position---either replace the pawls or a cheap way is to bend the throttle linkage so it develops more friction and doesn't move so easily
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
1 year 10 months ago #244576 by neil
Hello smokiejoe, your tractor is only 20 numbers newer than mine, 5U13753. Judging by the picture though, yours is in way better condition than mine : )
1 year 10 months ago #244618 by smokiejoe70
Is the parts something you can still purchase new old stock?
1 year 10 months ago #244620 by smokiejoe70
This dozer only has 4000 hours on it. It's hard to believe that the pawls would be wore out.
1 year 10 months ago #244625 by RobertShaver
iv fixed many of these by just taking the pawls out cleaning the crud from them and the other mating surface and stretching the spring just a bit that forces them against the housing. just mark the orientation of the throttle handle and the governor shaft before you take it off. 30 minute job
The following user(s) said Thank You: kracked1, juiceman, Fat Dan
1 year 10 months ago #244628 by trainzkid88
get yourself a parts book for your model you would be surprised what is still available from the dealer. there is also aftermarket suppliers for track gear parts. pistons engine bearings etc are also available aftermarket and genuine.
you can have a machine with high hrs that was looked after or a machine with low hrs that was flogged. the throttle ratchet being worn could be a machine that was constantly varied on speed rather than select a lower gear and run at constant revs.
1 year 10 months ago #244634 by neil
I think another option might be to turn the serrated ring some so it presents fresh serrations. I think I read someone suggested that on the forum, You could also put a bit more of a point on the pawls with a file. As for NOS parts, Florin, if they're still operating would be somewhere to look. You can also put your part #, when you get it, into machinerytrader's parts search
1 year 10 months ago #244640 by Glum
Bolt with a nyloc nut, so you can adjust the tension on the linkage,  to replace one of the clevis pins works pretty well.
1 year 10 months ago #244661 by smokiejoe70
Thanks guys. A lot of really good information. I will remove it and clean it first. Thanks again you've been really helpful in my venture.
The following user(s) said Thank You: kracked1, Fat Dan
Time to create page: 0.285 seconds
