Also have the grease can, but here's page one of the maintenance log. [attachment=70313]IMG_1428.jpeg[/attachment]![]()
Hi Moobi,
The tractor looks in excellent condition and a great acquisition, the bonus is getting the tools and hand books , that's half the challenge. Enjoy the the new toy.
Regards
Ps does the log book have a form number on it usually on the back of the book.
Daryl
Hi Daryl,
Thank you!
I'll be back with the tractor in two days, so I'll grab the log book and let you know.
Matt
Hello Matt,
Firstly welcome to the club, we do appreciate you becoming a member.
I see you are located in Gosford NSW, a couple of times when I visited Australia years ago I stayed in the Crown Plaza Terrigal. It was an amazing place and not too far from you.
I'm not sure if you are already a member of an ACMOC Chapter, but check out the Chapters page on the website if you havn't already where you will find details of Chapters as well as an interactive map showing locations of members around the world.
That's a really nice tractor you have there.
Thank you for your offer to scan the manuals you have for inclusion in the library.
I have just checked the library and we are in need of the following:-
The OMI (Operation and Maintenance Instructions) for the 4A bulldozer,
The Lubrication Oils book,
We do have copies of the others although yours may be cleaner copies.
I myself have never seen an original Tractor Operators Log book, and so if you could scan the covers and main pages (no need for all the detailed pages unless you want to). that would be great.
Regarding scanning the documents, if you have access to a suitable scanner that can scan the pages without splitting the spine of the book that would be great, the format we need id pdf. Otherwise it is possible to scan documents using an iPhone or Android phone. I'm not familiar with the latter, but using an iPhone you can open the notes app, create a new note and select the camera icon and scan up to 24 pages as one .pdf file. If you email the scanned copies to library@acmoc.org we can then put together the ,pdf files (if more than 24 pages) and add them to the library..
Regarding your tool collection.
I've been collecting Cat tools for several years and discovered that they are very hard to find mainly because they are not marked "Caterpillar" or "Cat", just the part number and tool manufacturer.
The main manufacturers that we see here in the UK are Armstrong, Billings and VLcheck.
I suspect that in your picture only the open ended spanner nearest the hammer is a genuine Cat spanner and should have a part number of 5B7xx
The long L shaped tool with the universal drive socket on the end is for adjusting the flywheel clutch and could be a 1B6109
The L shaped wrench to the right of the open ended spanners looks like a 9F22 which is used to bleed the diesel fuel system (bleed points on the filter tower and one for each fuel pump located behind the fuel pumps.
But you will know all this as you have the parts book !
That is an excellent example of a well kept D4!!!
WOW!!! That has to be the best kept D4 I have seen from "down under", as most are very well used up and thrashed! And to have the tools, manuals, etc. too! I really like the service records, reminds me of a KW truck I once owned, as the owner and driver kept meticulous records from day one to the very end; it was like reading a comic book for us as they would make comments about the economy or quirky items.
Glad we finally got to see some photos of your new gem, and glad that you are a new member! Keep on sharing please! JM
Very nice original 6U! I noticed it still has the factory trip-rope clip on the side of the seat, just above the square patent tag - those are usually long-gone. It's currently pivoted froward, but you can see the witness marks where it used to rub further back. When pulling an implement that was operated by a trip-clutch, you would put a loop in the end of the trip-rope and secure it under that clip on the side of the seat; if the implement should happen to come disconnected from the tractor (like a plow striking a rock and releasing the trip-hitch) then the rope would harmlessly come out from under that spring clip and stay with the implement should the tractor continue on a ways before stopping. Much nicer than having the rope actually tied to something on the tractor, or worse yet looped around the operator's hand lol
