Could anyone tell me if there is meant to be a plug in this threaded hole. Thanks in advance![]()
Hi Relic,
Simple answer yes, it has a cork (5b7267) in it to protect the thread.
Regards
No.40 scrapers were sent to NZ but not Oz. Your 7u looks pretty tidy. Where are you?
Restored as a member
Nice looking tractor!
i like the hydrualics set up. looks to be reasonably looked after. fitting the aftermarket pre cleaner must be a common thing the original with glass jar was probably a bit fragile. there certainly easier to get if you break it.
Can anyone shed any light on what this tag means? Thanks in advance [attachment=70112]A879F7F6-686A-47A4-89F7-150DD7C21C96.jpeg[/attachment]![]()
Thats, showing it has a standard transmission gear arrangement.
