Cat Thirty gas tank build.
1 year 11 months ago #243650 by Bruce P
Hi all. Here are a few pictures of a gas tank I just finished up for my Thirty.  I made it with two compartments, I’ll use the small one most of the time. It turned out ok I think.  I’m going to plumb it like the parts book shows for a duel fuel setup.  I’m going to put the strainer on the tank instead of hanging off the carburetor.
BP.
The following user(s) said Thank You: gauntjoh, jbernd56, ctsnowfighter, Markds3, Mike Waggoner
1 year 11 months ago #243651 by Kurt Bangert
Wow - Nice work!
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
The following user(s) said Thank You: Bruce P
1 year 11 months ago #243652 by D4Jim
Replied by D4Jim on topic Cat Thirty gas tank build.
That is one nice piece of work. Not only the forming but the welding and cutting. Did you use plasma to cut the plates? Not easy to get the dividers welded inside the drum.
That is impressive! Looks like you have done extensive work on the manifolds too.
Great Job.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
1 year 11 months ago #243653 by Bruce P
Replied by Bruce P on topic Cat Thirty gas tank build.
Thanks. I had my local metal shop roll the main tank and cut all the plates.  I cut the holes in the baffles at home.  I also made a non functional heat box for it awhile back.
1 year 11 months ago #243654 by trainzkid88
looks good now the big question does it leak. would be a good idea to seal it with a fuel tank sealer such as the por15 stuff or red coat now while its new and save a headache later particularly with todays fuel as most petrol now has ethanol and other corrosive additives.
1 year 11 months ago #243660 by juiceman
Replied by juiceman on topic Cat Thirty gas tank build.
Nice work BP. I like the compartment style tank, no need to fill the large one unless you plan on working it for some time! JM
1 year 11 months ago #243663 by Bruce P
I forgot to mention that I leak tested both compartments.  I use low pressure air and soapy water to find any leaks. I did find one bubbler on the partition that separates the different tanks.  I checked the big side first, before I welded the end on for the little side.
I’m not sure how I feel about sealing it.  Maybe I will, maybe not.
BP.
1 year 11 months ago #243664 by Rome K/G
Replied by Rome K/G on topic Cat Thirty gas tank build.
Nice work Bruce! That was a good idea for the dual tanks.
1 year 11 months ago #243665 by Bruce P
Thanks Rome.
1 year 11 months ago #243666 by ctsnowfighter
Very nice job Bruce -
I like the thought of the auxiliary petcock for priming fuel - nice addition.
It would not work in an orchard though - those errant limbs would find it quickly.
I really miss the Thirties and the Sixty -
"KEEP 'EM CRAWLIN"
cts
Time to create page: 0.211 seconds
