D7 1949 pony motor starter cross reference to 12 volt tractor starter
716thMP
Send a private message to 716thMP
I am looking for a cross reference starter that will work on pony engine. I can use the one I have but would be so much more convenient if it had a stud instead of a button. Thank you John
Wed, Dec 14, 2022 8:10 AM
josh
I bet you could pretty easily replace that button with a stud.
On the other hand, if you could find or make the parts to put it back to what it was, it is nice to have it so it engages both the starter motor and drive gear with the lever.
Wed, Dec 14, 2022 9:18 AM
Reply to josh:
A Delco 1107823 is the 12V version but it still is a push button unit.
You'd have to build a custom version to do the stud mount.
I've found that the China versions of the push button starter switch just flat don't work.
Look for and old Filko switch unit, they are OK.
Wed, Dec 14, 2022 9:47 AM
Newby Hall Tractor Fest
