the books i found in the tech library are for the later models.
My book for my 955, 12A7301,is a reprint of the Caterpillar Service Manual by Jensales. I found this manual on E-Bay. Money well spent for this machine. It does not explain how to get the transmission cover off to get to the brakes and steering clutches. That is covered in the D4 crawler Service Manual. Although from experience, to get the transmission cover off the Traxcavator Frame has to come off. There is a brace under the seat that connects the sides of the Traxcavator Frame at the back that sets right on top of the transmission cover. Once the Traxcavator Frame is off the machine what is left is basically a D-4 Dozer. I took the motor out of my 955 with the Traxcavator Frame still on the machine. I will never do that again. There was as little as a 1/4 inch clearance on the sides of the frame and the oil filter housing on the motor. I had to grind the top of a plug in the filter housing off to get the motor to clear. Once I got the motor out I went ahead and removed the Traxcavator Frame. It made putting the motor back in the machine much eaisier once I finished rebuilding it. I did not remove the lift arms and bellcrank from the frame. I only removed the bucket and used a small forklift in the front and a 2 ton crane in the back to remove the traxcavtor frame. I would not attempt to remove the Traxcavator Frame without the manual. I did a lot of things two or three times because I did not initially have the manual. This is one of the hardest machines I have ever worked on. Everything is so close and tight, it makes everything you do very difficult. I do not have scanning capability or I would send you a copy of my book. Good Luck bboaz
Caterpillar 955 Traxcavator Service Repair Manual SN# 12A1Caterpillar 955 Traxcavator Service Repair Manual SN# 12A1Opens in a new window or tab
New (Other)
$40.99Buy It Now+$3.49 shipping
Listed on E-bay 40.99 Buy it now
bboaz
Found my problem before I removed top cover.
[attachment=69824]IMG_20221201_112754835(1).jpg[/attachment]![]()
