Caterpillar D312 truck engine
Showing 1 to 7 of 7 results
Yoos Bros
Send a private message to Yoos Bros
Has anyone ever seen one of the D312 truck engines from the early 1940s? They were basically a D4400 with an automotive governor and different exhaust. I've seen the acmoc article on them and old brochures but am wondering if anyone has actually seen orĀ  has one. Thanks, Josh
Mon, Nov 21, 2022 5:18 PM
ChuckC
Send a private message to ChuckC
I think Jeff Moyle has one.
Tue, Nov 22, 2022 8:39 AM
Reply to ChuckC:
Never seen one before, but wouldn't it be cool to own one along with a 1693 and a 3408? I have truck nut friends that would enjoy having a mix of Caterpillar powered trucks. JM
Tue, Nov 22, 2022 9:29 PM
Are you referring to the D468 automotive engine? Series 1N3001-up.
Edit
After checking my rack setting chart manual I see a D312 Automotive s/n 1N6001-up, based on a D4400
Don't have any info on the D312 and have never seen one.
Looked up the s/n's, started at 1N6001 and ended at 1N6020 so not likely there are any around.
Ā [attachment=69653]catd468gi5.jpg[/attachment]
Wed, Nov 23, 2022 2:28 AM
josh
The spec sheet.
[attachment=69673]D312-1.jpg[/attachment][attachment=69674]D312-2.jpg[/attachment]
Thu, Nov 24, 2022 11:55 PM
Reply to josh:
The spec sheet.
Then there was the 3412 with a allot more horses! VROOM!
https://youtu.be/NTSVRr4LpGs
Fri, Nov 25, 2022 12:39 AM
Yoos Bros
Thanks for posting that spec sheet! I have an extra D4400 I'm thinking of converting into a D312 basically to install in my one 1940s Mack EF. I'd like to keep as close what they were as possible. I believe like govenor was basically that of the D468/D4600 used in the early DW10s so that may be able to be found. The manifolds I'm sure I'll need to fabricate. I believe from my parts book though the intake maybe similar to that of the D4400 marine engines.
Sat, Nov 26, 2022 8:18 PM
josh
Reply to Yoos Bros:
If you don't have it already, there are a couple D312 automotive engine parts catalogs on ebay, I could try to cross part numbers to see what applications the parts had, although for some of the low production units and parts, the NPR does not always list.
https://www.ebay.com/itm/371944218500?hash=item56999a5f84:g:VfQAAOSwurZZEMds&amdata=enc%3AAQAHAAAAsFgzJHxPjw19JwXbGsogq3Np%2FYIKb7xchHJ0szDl%2Fl3wzEGYzTI54MZ96QucNHS9Lkmh2LhwCPIKEoAHEotcTQOssiYtAzTiQ6aFIgavEtFCMuT0kjkuf9dQVCFgjKa7AdSI7DrT9BB37s08KPdE9bbC6%2B0fMm6ThJm8s%2F9q7PD%2BqHZBchC%2FXg8zF9lPyXidEf%2FhXSX%2Bi1ZFVYo6hzo7wSG99DpViXhHb%2Fqd5OA8k4pr%7Ctkp%3ABk9SR_7rjM2WYQ
Sat, Nov 26, 2022 11:45 PM
Newby Hall Tractor Fest
