D2 Cat with factory Direct Electric Start.
Showing 1 to 9 of 9 results
Dandy Dave
Send a private message to Dandy Dave
Recenty Aquired a 1956 D2. I haven't had one in a while and this one became available. Looks like I'm going to be doing Steering clutch work and relining the brake bands. Seems parts are harder to get these days. The last ones I was in was around 30 years ago. I could not pass this one by though so it is here on the farm. I have not seen many around here with the direct electric start option. Wondered how many had this option? It took me a few days but I do have it running after a 15 to 20 year sleep. Steers on right side. Brake adjustments are all used up. Here I go again.
Sat, Nov 12, 2022 9:25 PM
Bruce P
Looks like a nice tractor overall. It will be a good playmate for your grader.
Bruce.
Sat, Nov 12, 2022 10:09 PM
cheshire cat
Send a private message to cheshire cat
Reply to Bruce P:
Bruce.
Nice find , looks nice and original , I also have one Mine is 5U18856 No blade but has the oil clutch I know of another 5u direct start bare tractor thinking it’s about 1956
But they are few and far between.. seems there were a fair number of tail seat ones in California .. [attachment=69498]B69D3AB9-9182-4402-9A57-6FB62FC4189B.jpeg[/attachment]
Sun, Nov 13, 2022 12:37 AM
Thank you received: 30
Reply to cheshire cat:
she was a farm crawler originaly by the looks of it or was ordered with PTO.
Sun, Nov 13, 2022 2:43 PM
Dandy Dave
Actually someone has done a swap at one time as the engine is not the same serial as the rearend. Looking at the peddles it has a lot of hours on the rear end at least. Both serials are in the 1956 range though. Engine is  5U18318. Rear tag is 5U16176.
Sun, Nov 13, 2022 9:48 PM
Reply to Dandy Dave:
yeah id say its had a repower.
Mon, Nov 14, 2022 2:30 PM
Dandy Dave
Some You tube video of it starting and running I made a few days ago.
https://youtu.be/PfVK8Qju9DA
https://youtu.be/A596AZ_t98g
https://youtu.be/jLwK_CK8IZo
https://youtu.be/3A-emoOpWEE
https://youtu.be/pJ9f6ax6rXc
Mon, Nov 14, 2022 8:16 PM
TomTrack44
Send a private message to TomTrack44
A friend here in northern California has one with direct electric start, we had the starter out, the generator off and replaced the regulator. After chedcking them, replaced them and n
ew batteries and she fired right up, nice tractor.
Tue, Nov 15, 2022 3:31 AM
Delta KJ
Reply to TomTrack44:
I have a 1956 direct start D2 as well.  I am envious of your starter switch; Mine is missing the contact that activates the glow plugs.
I made a battery box and battery plate for mine and I posted the process here on AMOC if you are interested.
Nice D2!
Kevin
Tue, Nov 15, 2022 4:01 AM
Dandy Dave
Reply to Delta KJ:
Nice D2!
Kevin
[quote="Delta KJ post=242513 userid=1123"]I have a 1956 direct start D2 as well.  I am envious of your starter switch; Mine is missing the contact that activates the glow plugs.
Nice D2!
Kevin
I saw your ad for an old switch for parts. I had to take this one apart to clean it and found out that you need to take the cover off slowly or the contacts will fly out. [img]/media/kunena/emoticons/w00t.png[/img] I use to run a 212 grader that also had the direct electric start option. We use to tow it to start it 30 years ago. About 6 or 7 years ago I helped with engine work and while doing that I cleaned up the connections to the glow plugs and it started and ran like it should. The fellows that owned it kicked and cused that they should have done that years ago.
 [/quote]
Tue, Nov 15, 2022 8:45 PM
Newby Hall Tractor Fest
