Clearing slope
2 years 2 weeks ago #242198 by JohnnyJ
Clearing slope was created by JohnnyJ
Walking an area to be cleared for a river view from a new home build site. Noticing the area to be cleared is too steep to maneuver while on the slope except straight down and back up, no turning to chance a possible rollover. Question does the steep angle promote poor cylinder wall lubricating with oil all to one end while going up and down? I know the history of these machines included all types terrain.. still was wondering. And would the use of additives help this issue?
2 years 2 weeks ago #242199 by Walt D7-3T
Replied by Walt D7-3T on topic Clearing slope
I do not know about the "modern" Cats, but back in the 60's and so forth. The engines had two oil pick ups in the crank case, front and back, so the oil in the crank case was "always" available even if you were climbing a hill or going down...
That is ALL that I know...
2 years 2 weeks ago #242216 by JohnnyJ
Replied by JohnnyJ on topic Clearing slope
Thanks Walt. Much appreciated. The one I have is a ‘52 ..  I hope it does have the dual you’re speaking of..maybe  there’ll be more input.
2 years 2 weeks ago #242217 by Deas Plant.
Replied by Deas Plant. on topic Clearing slope
Hi, JohnnyL.
You don't appear to have mentioned the machine that you will be using for this clearing. That also will make a difference as different machines have different engine lube systems..
Just my 0.0.2
2 years 2 weeks ago #242219 by JohnnyJ
Hi Deas,   Same tag # is on motor and back of dozer.
2 years 2 weeks ago #242220 by JohnnyJ
Anyone know what the 734 tag is?
2 years 2 weeks ago #242222 by Deas Plant.
Hi, JohnnyL.
Atta guess, 734 would be a government # at some level of the bureaucracy. Others here will likely know more than me 'coz I'm from DowNunda.
The 3T D7s were a pretty stable machine. Just make sure that your brakes are properly adjusted and working well and keep the blade low - - - or am I preaching to the choir here?
2 years 2 weeks ago #242231 by JohnnyJ
Ha not hardly preaching to the choir.. my experience on this cat has been mostly flat ground. Always appreciate as others I’m sure your.02 on various issues..
2 years 2 weeks ago #242233 by Deas Plant.
Hi, JohnnyL.
Regardless of whether climbing face first or 'bass ackwards', keep the blade low. Face first, it helps to hold the front down. 'Bass ackwards', it tends more to hang from the push trunnions rather than lifting the back end off the ground levering over the front idlers as it would do if it was up high.
Most dozers are remarkably stable sideways on slopes too. The GREAT majority of operators will 'press the chicken switch'. I have personally had a Cat D9N dozer on a MEASURED 43 degree side slope TWICE - different situations and it never felt like it was about to lift the high track. In fact, the second time, I was turning toward the low track all the way trying to get away from a boggy area on the slope and the high track never lost traction, was driving the whole time.
BUTTTT, it'z still best not to push the limits.
But what would I know? I'm 'justa pore, dumm bulldozer op'rator from DowNunda'
Just my 0.02..
2 years 2 weeks ago #242239 by JohnnyJ
Seems like the reverse has as much torque power wise backing as the going forward does. I won’t be horizontal on the steep portion of slope ..
Time to create page: 0.205 seconds
