RAD Replacement Suggestions
Thank you received: 16
2 years 1 month ago #241744
by Xtremist
I need a replacement RAD core for my D6C. Holy crap are they ever expensive !!! The local RAD shop wants $3700 to recore it, union tractor wants $2500 just for the core, no labor. Seems a bit steep to me. Does anybody have any suggestions for a cheaper avenue....? Id even consider building my own as I am a competent tig welder and fabricator but have no idea where to source components..... any insight would be invaluable and greatly appreciated. Thanks
Thank you received: 90
2 years 1 month ago #241746
by kittyman1
-have you checked with any other aftermarket suppliers for heavy equipment? near me there's a company ON-TRACK, etc....usually not Cat quality but much more reasonable cost
-what about heavy equipment wreckers? maybe something out a big tractor (or truck)(or big equipment) might be close or be modified to work....
Xtremist
Thank you received: 775
2 years 4 weeks ago #241761
by juiceman
We just had one done for a D5 98J, and had a bit of a wait time (none available) price was about the same as your D6C cost. JM
Thank you received: 789
2 years 4 weeks ago - 2 years 4 weeks ago #241788
if you could get a alloy rad about the same size you could mount it inside the old housing so it looked the part. try truck or macinery wreckers they might have something. try aussie dessert coolers or PWR they both do custom stuff for hot rods and other applications
Xtremist
Thank you received: 24
2 years 4 weeks ago #241844
by d9gdon
I think I paid over $4000 just for a core for a D7G about 3 years ago, so your prices are not out of line especially with this transient inflation we're all enduring...and I say that tongue in cheek.
2 years 4 weeks ago #241850
by kittyman1
Trainzkid88, when you say ALLOY do you mean aluminum rad core? might throw us off course in North America...slightly different meanings..
- my guess/experience.. is aluminum is the way to go, don't know all the options and history of rads... aluminum moves heat as good as anything commonly available..
Thank you received: 121
2 years 4 weeks ago #241851
by PhilC
Normally an alloy would mean a mix of metals so I assume Chris meant Ally which is of course short for aluminum as it is known in North America:)
It is still not as good as copper for transferring heat. There are two main reasons manufacturers went to aluminum and that is cost and weight.
The reason the radiators are smaller probably has more to do with the internal design of the engine.
By the time you get someone to build you an aluminium radiator you probably won't have much change left out of $2500. These radiator's arn't small and you need to do your calculations before diving in and sticking something in there that does not work and you have spend another $2500 on a core anyway.
2 years 3 weeks ago #241884
by kittyman1
thanks for the clarification Phil, makes sense
-yes be careful to not go down the wrong path and end up doing/ spending twice!
2 years 3 weeks ago #241890
actually certain aluminium alloys are better than copper and brass for heat dissipation. and yes due to cost, weight, ease of manufacture aluminium has taken over.
a boilermaker i know borrowed a mutual friends stick welder that had aluminium windings, while his was in for repairs gavin wanted to keep it and he explained why as the windings didnt hold heat like a copper based machine of same size. it meant he could work for longer due to the higher duty cycle.
yes niether option will be cheap. where the saving might be is if you can get a off the self unit that is suitable. the [roper replacement core has the advatange you know it will work its guaranteed to fit.
2 years 3 weeks ago #241899
by PhilC
Time to create page: 0.182 seconds
