D8 H36a pony motor
16 years 2 months ago #20943 by bs7853
D8 H36a pony motor was created by bs7853
D8 36a617
The pony motor dosent want to start. The questions are what spark plugs should it have? It has chanpion in it. What is the electric starters voltage 6 or 12? The pony motor dosent like to start to often and i have found that there is moisture in the points and cap i think it is condensation. What can I do to prevent this from happening? And what can i do to make it start better?
Can you rilly use the hand crank to start it? I and haveing problems with the electic starter too. Is there a replacemet for the starter or do you have to have it rebilt or find a used one?
16 years 2 months ago #20957 by gemdozer
Replied by gemdozer on topic D8
You could use NGK plug and our magneto cap must be crack and the startor should be 12volts and am still have poney parts.
16 years 2 months ago #20975 by bs7853
Replied by bs7853 on topic D8 H36a pony motor
What ngk plug should i use? My parts book tells me i have a 6 volt starter. i hope that is not right becouse it has ben on a 12 volt battery for a while. if any one knows that would be great.
16 years 2 months ago #20976 by catskinner
Replied by catskinner on topic D8h
Yes you can use the hand crank. I used mine for years on my D7 and second pull it was running. catskinner
16 years 2 months ago #20981 by Old Magnet
Replied by Old Magnet on topic D8 H36a pony motor
The D8 36A pony starter motor is 12 volt.
Use NGK A6 plug for 18mm replacement.
Use NGK BP-4 plug for 14mm replacement.
You'd have to be some kinda "gorilla" to hand crank that 1246 cu. in. D342:eek:
16 years 2 months ago #20998 by Old Magnet
Aaaaaahhh!! Had a brain short on that one. I didn't even occur to me at the time that it was in reference to the common practice of hand cranking the pony motor. Not a good sign:o :o
Time to create page: 0.135 seconds
