Hi Langdon,
Welcome to the forum, you will get a lot of help on here as well.
The first thing I would do is get yourself a parts book for the grader it helps so much in tracking down part numbers.
As for parts you will be surprised what Cat still supply for these older machines.
You can always have the master and slave cylinders rebuilt with new stainless sleeves and new lines made.
Regards
The lines and cutting edges are both supplied by Cat yet. The master cylinder and maybe the wheel cylinder can be sourced from a local parts house with the Wagner casting number on them.
My 12 8T15911 parts were fairly easy to source via Florin and our local auto parts store, just as others have mentioned. The 212 should not be challenging to source. Best wishes.JM
Thank you all for the welcome to the forum - I really appreciate having access to and replies from so many knowledgeable and experienced people.
I have looked up the parts manual for the 212 here in the library - that's a fantastic resource by the way. I'm looking forward to digging into the various 212 books.
That is great news that Cat will still supply major parts like the lines and cutting edges. That definitely makes this purchase worthwhile. I will call Caterpillar and see what they have to say about supply here in Australia. Their online parts system was zero help, so I figure that I need to talk to a real person.
FroghairFarm - you have a great list of machines there, a D4 (or bigger) is definitely on my shopping list longer term, but I have about 3kms of dirt road to my farm that need serious maintenance first, so the old 212 is totally justifiable for me!
Thank you again to everyone who replied - I really appreciate your feedback and will be going ahead with the purchase now I'm confident I can get the parts I need.
I thought I would just mention for anyone in the future with a 212 grader that I was able to source the flexible brake line components off the shelf from Caterpillar. They also believe that they have suitable blade cutting edges, but I haven’t ordered them as yet.
Langdon
the bolts for cutter edges are available any good bolt supplies called plow bolts
buy according shank dia and overall length
Thank you for the tip on the bolts Trainzkid88!
