Early D4 6U Regulator options ?
16 years 2 months ago #20873
by WraithGTO
Gday
I am in the Process of cleaning the cooling system on the D4 6U #300
Upon removal of the top housing of the thermostat, I found There is no regulator to be found just a big empty hole:eek:
On further reading here I have worked out that Cat changed the lower housing to suit newer Thermostats(Regulators)
Looking at my lower housing, I can't seem to find the part# on it, to see if it is the early or late type housing, and which Regulator to buy.
These are the options I have found so far
Option A
1. I did find a post that says a 6F-9467 Regulator is to suit a D4 6U, Is this regulator a Lower serial# type D4 6U one or a later D4 6U one please ?
2. Is a retaining ring required to secure this Regulator and what is the part number please?
If it the early type Regulator I could go this way, and buy a regulator and the retaining ring
Option B
On further reading I found a article which says you can use these following parts can be used in replace, of a Housing which uses 6F-9467 Regulator
8F-8817 Regulator
8F-8882 O-Ring
8F-8884 Retainer
2H-4939 Retainer
2F-8518 Gasket
I could go this way, but it comes back to not knowing if a 6F-9467 is too suit my housing
Option C
Or change the housing and put a later model
2H-5847 Later style Housing
2H-9986 Thermostat
2H-1172 Gasket
All I can tell you about my Regulator Housing is it is has a lip about 20mm down inside the bore at the same level as the inlet for the bypass passage, and I can't seem to find the #number located on it, It is maybe on the block side?
Cheers
Simon
Thank you received: 10
16 years 2 months ago #20879
by ccjersey
Call up CAT dealer, I expect they will sub it out for you and you will wind up with a standard thin flanged automotive style that rests on the gasket ledge and a gasket that fits around it.
Or go to auto parts house and select one, they may have a listing for D311 or D2.
Thank you received: 820
16 years 2 months ago #20883
The 6F-9467 regulator and 8B-9828 retainer fits 6U-1 to 6U9063.
The later style regulator requires a housing change to a 2H-5847 (no retaining ring) and was used from 6U9064-up.
I don't have any info on that last series of numbers for conversion. Would be curious to know where the info came from and if it works:)
16 years 2 months ago #20949
by WraithGTO
Cheers for the help Old magnet and CC
You guys have been a big help once again.
Now I know with info you gave me my tractor should have a housing to suit the 6F-9467 Reg,
Old magnet would you possibly please have a scan of the older style lower housing to suit the 6F-9467 regulator and one of the newer style housing please out of the parts book.
In my D315 service manual the picture of the housing looks to be a very generic picture ( Just a flow diagram ) and I cant compare it to my housing, Be a big help so I can order the correct regulator please.
I have contacted the local Cat dealer all of the parts quoted are discontinued but the 6F-9467,8F8817 ( regulators ) are still available.
Old magnet I found the info for the update on a service gram that OzDozer had posted on one of the forums, If I can find the thread again , I will post a link to it for you
CC I have thought about what you have suggested, but when the regulator opens it shuts off the bypass channel, and trying to find a aftermarket automotive one that will close the bypass channel off maybe impossible to find, but you never know.
Cheers for the help guys
Simon
16 years 2 months ago #20986
Per your request:)
There is one more even later style just like the late unit but it does not have the bolt on cover
16 years 2 months ago #20988
by WraithGTO
Gday Old Magnet
The pictures are excellent and thank you very much for posting them, I very much appreciate the help,
Judging by the 2 pics, my housing is the early style, as by looking at the pic the bypass water channel is cast into the housing early type and the later style has a inspection cover 3H-5572 over the bypass channel and the top of the housing is more square.
Thanks again old magnet
Cheers simon
Time to create page: 0.144 seconds
