Need part number for R2 J oil filter
Showing 1 to 6 of 6 results
Peter C
Send a private message to Peter C
Hi,
I'm assuming that this is the oil filter for my R2 6J. My parts manual doesn't show a filter at all. Can anyone tell me the filter part number? Would it be the same as a D2 J series?
It hasn't been running for over 12 years and I've been soaking the cylinders with loose juice try to free up the rings. I want to change the oil before I attempt any starts.
Pete
 [attachment=68881]oil filter (2).JPG[/attachment]
Wed, Sep 7, 2022 7:35 PM
That style should use a 1R-0659 filter. Looks like it has been updated. The cap uses a 5B5937 gasket [seal]
Wed, Sep 7, 2022 10:20 PM
Peter C
Thanks Rome. The Cat dealer is about 40 miles away so I like to be able to ask with a part number in hand.
Pete
Thu, Sep 8, 2022 7:54 PM
Reply to Peter C:
Pete
Might want to remove the old filter to make double sure and see if it has a number on it.
Thu, Sep 8, 2022 8:31 PM
Peter C
That's a good idea. I will do that when I get back to work on it.
Pete
Fri, Sep 9, 2022 2:02 AM
Reply to Peter C:
Pete
Peter---my 6J1 parts book shows 6B7697 filter and 7B2762 gasket---the picture shows the early style T handle on top
Sat, Sep 10, 2022 8:56 PM
Reply to dpendzic:
That would be the bypass type oil filter, he has the one with the hex nut and slot which is full flow.
Sat, Sep 10, 2022 11:55 PM
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
