Fitting size and thread in radiator drain of D8 13A
Michael Crowe
Send a private message to Michael Crowe
The dozer is three hours away in a remote area not close to a hardware store.  Can anyone tell me what size the threads are in the radiator drain.  I put in new antifreeze and after flushing the system, I have a small gasket that wants to seep.  I was hope to drain it down but with the belly pan there is no way to not contaminate it unless I can screw a fitting into the drain fitting and attach a hose.  Thanks.
Thu, Aug 11, 2022 12:09 AM
kracked1
I think it is 1/2NPT thread. Possibly 1/4NPT. grab one of each and bring along. They are only a couple bucks each.
Thu, Aug 11, 2022 12:38 AM
Thank you received: 28
Reply to kracked1:
all threads on these older machines are SAE so npt, nps unf unc uns maybe unef all pipe fitting should be npt or nps.
Fri, Aug 12, 2022 7:18 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
