Hmmm.. maybe try a long cheater? Large impact?
Watched the Jpaydirt video - spoiler alert, they used backhoe to push on wrench - and I found a 2-1/2" wrench on Ebay that looks strong enough to hit with sledge hammer or push on with backhoe. I thought the 1" drive socket and breaker bar would do the job, but the way it flexes makes me think I could break the tool before the nut comes loose.
Why are you removing that nut?
Removing nut to build a hitch for a log arch - copying design from photo of Hyster hitch that went with the D2N winch.
[quote="Claremontcat post=239710 userid=16625"]I thought the 1" drive socket and breaker bar would do the job, but the way it flexes makes me think I could break the tool before the nut comes loose.
[/quote]
Unless the 1" handle is low quality you should not be able to break it. I have had a 6 foot piece of pipe on my tee handle and doesn't even look like breaking. For a nut that size you could also try using two hammers to persuade it a bit. Use one as a dolly and hit the opposite side of the nut. i have had nuts come loose just using that method.
Heat it with a acetylene torch and make it red orange. Hit it with one of those Milwaukee M18 3/4" impact guns. They are very impressive. That may be all you need without any heat.
I doubt you'll make it hot enough with a MAPP gas torch.
heat it with a proper heating tip and oxy-lpg(propane) ( much better for heating) let it cool and try again (mapp torches are for soldering plumbing). if you have a cutting torch get a piece half inch plate and cut out a slogging spanner as its made of steel plate it doesn't matter if you bend it where as big spanners get expensive fast.
a mix of kerosene and diesel works well but it takes time soak it heavily and let it work reapply as it soaks in.
that thread might be a bit burred over file it tapered a bit that might help ive chased burred threads with triangle files and a hacksaw blade.
ive done as phil suggested too it works surprisingly well some thing about actually getting a proper hit on the part, the second hammer sort of acts like a mirror and reflects the force dont ask me the physics ive just had it work. works well on tie-rod ends and ball joints
