Need Help to IDENTIFY YEAR D2 Serial plate is off engine and trans Winch covers
Showing 1 to 10 of 10 results
G2D2
Send a private message to G2D2
Howdy from Oregon y'all!
I just bought a Caterpillar D2 and the engine tag is missing and the tag on the trans is hidden by the Winch.. I have seen similar ones that say they are 1951 or 1953?  But I would like to know for sure and I know for sure someone here can ID it 😊 [attachment=68429]IMG_2530.jpeg[/attachment][attachment=68430]IMG_2532.jpeg[/attachment][attachment=68431]IMG_2531.jpeg[/attachment][attachment=68432]IMG_2533.jpeg[/attachment][attachment=68433]IMG_2529.jpeg[/attachment][attachment=68434]IMG_2542.jpg[/attachment][attachment=68435]IMG_2536.jpeg[/attachment][attachment=68436]IMG_2537.jpeg[/attachment][attachment=68437]IMG_2538.jpeg[/attachment][attachment=68438]IMG_2539.jpeg[/attachment][attachment=68439]IMG_2534.jpeg[/attachment][attachment=68440]IMG_2535.jpeg[/attachment]
Sun, Jul 24, 2022 7:52 AM
josh
Thank you received: 13
In the 4th picture, you can see where the serial number tag on the engine block was, there is one rivet left and a hole for the other rivet, if you scrape the paint off between the two rivets, you may be able to see the serial number stamped in the block.
Sun, Jul 24, 2022 8:20 AM
Disqualified
Send a private message to Disqualified
Reply to josh:
When I was playing this game with my d4, old magnet said to check the engine oil pan flange. I found the serial number neatly stamped right there.
Hopefully that might help you too..
Thanks again old magnet
https://www.acmoc.org/bb/discussion-d72/28630-help-identify-my-d4
Sun, Jul 24, 2022 2:28 PM
Reply to Disqualified:
I would say more around 1947-1949
Sun, Jul 24, 2022 5:59 PM
Thank you received: 74
The transmission at least is post 5U13273 (or the 4U equivalent) because it has the two-piece clutch shaft which would make it in the early '50s I think. I'm wavering on the dash forward though without my parts catalog because the gauges are not mounted on the separate small dash unit - I don't know when that change was made, and the governor control does not have a remote handle mounted on the governor assembly itself. The fenders are also pressed steel. I suspect the transmission and engine serial numbers might not match but only one way to find out for sure
Sun, Jul 24, 2022 10:19 PM
Thank you received: 60
The fill plug vs two bolt cover on the pony clutch housing puts it in the 47-48 era. Course it could have been changed.
The transmission shift lever puts in the late class. Looks like a hybrid mix. Can't quite see the compression release mechanism.
Sun, Jul 24, 2022 11:27 PM
G2D2
Reply to josh:
Thank you! I will try and strip the paint
Mon, Jul 25, 2022 11:13 AM
G2D2
Thank you!  I will Check the flange, going to change the oil tomorrow.
Mon, Jul 25, 2022 11:15 AM
G2D2
Neil, Great stuff Thank you!!   At 5U16128, an oil clutch became standard where would I look for an indication of that?
I will have to become a Member of ACMOC if they have all the parts books in .PDF?  looks like they have a good bit of literature anyway.
Mon, Jul 25, 2022 11:28 AM
G2D2
Old Magnet, I appreciate the info!  I will try and take a better photo of the compression release I know it's brass.. From what you and Neil have said I'm thinking at some point it was updated to a new tranny and some parts were swapped here and there.
Thank you!
Mon, Jul 25, 2022 11:34 AM
Thank you received: 54
Reply to G2D2:
Thank you!
that was one thing about cat a lot of later model parts would fit earlier machines. and yes re-powers were common particularly for company and local authority machines they didnt have time for it to sit to be repaired so often a exchange would be done. and its still that way today cheaper and quicker to do an exchange or have a spare to put in now and rebuild the broken unit as time permits.
Thu, Jul 28, 2022 9:28 AM
