help with fan belt
help with fan belt
Showing 1 to 10 of 11 results
jbernd56
Need a fan belt for 1942 R2   4J1098.  Parts book says 6B 1089.  Does anybody know if that is a good number.  OR does anybody know a crossover number and belt that will work?
I have not tried local CAT place yet. Was hoping someone had already gone down that road and could save me a few steps.
This particular model has a generator,but it runs on a different belt and I have not started on that project yet. It has what appears to be a homemade adjuster on it.  The generator mounts solid on the engine and not sure how the belt stays tight.  I have the adjuster working well for the fan belt.
As always, any help will be apprieciated.
Fri, Jul 15, 2022 2:05 AM
6B1089 comes up as a bearing race cup.
Fri, Jul 15, 2022 2:13 AM
josh
Thank you received: 6
Fan belt is 6b1039 or 2b0463. The generator belt has no tensioning provisions, as things wear a thick paper shim is often used under the generator.
Fri, Jul 15, 2022 2:34 AM
bruce oz
Thank you received: 20
[attachment=68387]119178056_3645437978834046_267782357123027665_n.jpg[/attachment]
Fri, Jul 15, 2022 5:27 AM
Reply to bruce oz:
Sometimes you need a telescope to read those part numbers in those old books. lol
Fri, Jul 15, 2022 5:37 AM
jbernd56
Many thanks! You are correct, it is 1039. I typed 1089 instead. I will see if NAPA can cross that number. If not I guess I will go CAT. NAPA is much closer to my house!
When I was looking at the mounting for the generator, I thought I was seeing some kind of stuff that looked like tin foil or some kind of thin metal still attatched to the machine. In the parts book, they list 3 shims. probably what I am seeing.
Since the fan belt was a good number, can I ASS U ME generator belt number good too? 5B 243.
As always, thank you for the help. Worth every penny of dues to belong to the club, to be able to access the vast quantity of knowledge just a click away!
Fri, Jul 15, 2022 7:26 PM
josh
Reply to jbernd56:
5B243 is the correct number, the size is, 11/16" x 38.5" I don't think they are available from Cat, and finding an exact replacement may be tough, finding the same width and length may not be possible, as most of the replacement belts I see are a little narrower. That may not matter with applications like the fan belt where there is some adjustment available, but with the generator belt, you may have to use a slightly shorter belt if it's narrower, and there is usually some wear on the pulley.
Fri, Jul 15, 2022 9:57 PM
jbernd56
Reply to josh:
You are correct, 5B243 is not available. Got the fan belt coming from Waco Tx It amazes me that they can have a 45 inch belt, but not continue to have a 38. Oh well. Thanks for the measurements. Fortunately, the parts store guy and I are neighbors. I am their favorite customer. Between Cushman and Caterpillar, Whenever I come in, all the counter people do a ;quick round of rock paper scissors to see who gets to help me this time!!
Fri, Jul 15, 2022 10:16 PM
Thank you received: 23
Reply to jbernd56:
If you're ever looking for a generic v-belt, vbeltsupply.com has a wide range that increases in size by one inch. They're as cheap as dirt so when I've purchased, I've ordered the two sizes either side in case the sizing is inaccurate
Sat, Jul 16, 2022 7:55 PM
jbernd56
Thanks, I will give it a try.
Sun, Jul 17, 2022 9:03 PM
jbernd56
Reply to jbernd56:
Gave it a try. Not smart enough to navigate the web site.  Too many choices. Guess I will call on Monday and embarrass myself on the phone.
Sun, Jul 17, 2022 9:50 PM
Price Tractor Pull
Price Tractor Pull
