Final Drive Nut
Final Drive Nut
Thank you received: 83
16 years 2 months ago #20730
by bernie
I am looking for the correct socket to use on final drive nut L-2341. I took them off with a pipe wrench and come along, so I did not have it for disassembly.
I measure 2-5/8 inch. I am having a dog of a time finding one that size without breaking the bank. Not in the mood to borrow one-
Can someone confirm that size?
Thanks-bernie
16 years 2 months ago #20734
by bernie
FYI-I got the answer I was looking for. For reference the L-2341 requires a
2-5/8" socket as I had thought. Glad to have the confirmation before dropping the $$$.
thanks-bernie
16 years 2 months ago #20743
by bernie
I've used them. When we were disassembling my clutch packs on my D42T we tried one of those first...tore the daylights out of it. Good suggestion-it would probably tighten the nut down fine.
But...what would end up happening, I would trash it while torqueing it on and end up still needing to pick up the correct impact socket.
Thanks for the suggestion Carl-
bernie
16 years 2 months ago #20747
by steamroller
bernie
If you need a 2-5/8" go to NAPA they have good steel USA made sockets cost about $25.00.I bought a 4" 2-5/8 3-1/4.Sears also has a 2-5/8 for $30.00
Hope this helps. Steamroller:cool:
16 years 2 months ago #20752
by SJ
Snap-On only shows a 2 5/8" in 1" drive so the impact socket # is for the standard length is 1M843. I,m sure Mac or the NAPA would be a little cheaper.The Impact would be a lot stronger than just a regular socket.
Final Drive Nut
Time to create page: 0.151 seconds
