CAT D4 7J info
CAT D4 7J info
MARTYN WILLIAMS
Hello there
Could someone tell me the measurments of a 7J,width, length and weight in working order?.A data sheet would be of great help.
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Fri, Sep 12, 2008 4:23 PM
bruce oz
hello MARTYN,without knowing what make of blade you have or weather it cable or hyd it is hard to give measurements .bruce oz
d47j tractor ,weight 10030 pounds
,length 10' 1 9/16''
,width 64''
blade could be(straight blade) 6' 10'' or (angle blade) 9'9'' wide ,added another 24'' to 30'' in length and blade could width another between 2,300 to 3,270 pounds ,
Fri, Sep 12, 2008 5:10 PM
MARTYN WILLIAMS
Reply to bruce oz:
,width 64''
Hello Bruce
I think it had a Birtley hydraulic blade.Will be seeing it on Sunday.Will post pictures.
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sat, Sep 13, 2008 2:15 AM
bruce oz
Reply to MARTYN WILLIAMS:
Hello Bruce
Martyn
hello MARTYN ,is this the one your look at ,look good ,like the old cats for over there ,always look a bit green from sitting in the damp,bruce oz
[img]http://www.norwest-trading.co.uk/images/catd4_2lg.jpg[/img]
Sat, Sep 13, 2008 6:12 AM
MARTYN WILLIAMS
Reply to bruce oz:
Hello Bruce
Its im much better condition than that one if I remember ( first saw it 5 years ago).All it needs is the mag to sort out.Will take pictures tomorrow and keep you updated.
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Sun, Sep 14, 2008 1:15 AM
MARTYN WILLIAMS
Hello Bruce
Martyn
Saw the D4 7j today,its a good machine with very few things to do on it.
One job that will need doing is the front idler.Has anyone drawings of the idler,there appears to be a spacer block missing between the frame and idler casting.Can anyone help?
The machine dates from 1942.
Many thanks
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Mon, Sep 15, 2008 2:25 AM
| Hartley - South Australia
