Cat 955 12A series
Cat 955 12A series
BillySanders
Send a private message to BillySanders
Does anyone know if a 955, 12A series with a pony start engine can be fitted with a direct start starter.  Is there room for a starter, is there already a hole in the side for one??
Any info would be greatly appreciated...
Fri, Apr 29, 2022 11:23 PM
Thank you received: 39
Yes and yes. The 12A's have provision for direct electric start including the larger diameter pre-combustion chamber heads that allow use of glow plugs.
Sat, Apr 30, 2022 12:50 AM
Fat Dan
My herd of Cat 955 12A's
I like using the pony motors mainly because I live in Alaska and cold starts are hard on everything.
Oil pressure comes up slowly in the D315 and D318. I believe the filter hosing needs to refill on each startup, Keep a close eye on the oil pressure.
NEVER EVER use either with glowplugs !
Good luck
 [attachment=67537]IMG_3877_Moment(😎.jpg[/attachment]
Sat, Apr 30, 2022 2:21 AM
Fat Dan
Reply to Fat Dan:
Good luck
FYI as per Ol Magnet ... thanks OM,
@ 12A5793 the undercarriage went from a D4 to a D6
Sat, Apr 30, 2022 2:23 AM
