Type of carburetor?
Type of carburetor?
Showing 1 to 10 of 15 results
catjoey18
Send a private message to catjoey18
Can someone name the model of ensign carburetor this is?and where to find rebuilt parts or kits or where can I have someone do it for a fair price and is it a original for a caterpillar twenty?Any information much appreciated thank you.
Fri, Apr 22, 2022 12:32 PM
Thank you received: 34
i would take it to a local small engine shop and have it sonic bathed after giving it a good soak in hot soapy water to rinse off some of that crud. the model should be cast stamped on the side. a little CLR or the like will help disolve the encrustation short soakings only. white vinegar also works and is cheap. use a old tooth brush to scrub it. note it must be rinsed well and oiled with rp7,wd40 etc to prevent flash corrosion.
do you have a parts book for your machine. if so try the dealer or florin tractor they should be able to supply parts. if your a acmoc member you would have access to the member library. there is a copy of the parts book in the library.
i just found it yes its not real clear to read but it does have the part numbers. and a google search with those numbers might just get you the ensign company numbers and then you might be lucky at a auto parts joint.
Fri, Apr 22, 2022 4:38 PM
Reply to trainzkid88:
it has the ensign numbers listed so you might be in luck.
Fri, Apr 22, 2022 4:54 PM
biggastractor
Spent a half hour looking for a chart of ensign carbs and the CAT tractors that they fit but I cant find it anywhere. Chad Enyart should be able to help you. He's an ACMOC member
Good Luck
Fri, Apr 22, 2022 7:47 PM
naylorbros
Reply to biggastractor:
Good Luck
Look like either an AEL or an AES. If I had to guess I would say AEL which is for the early Twenties. On the flange that has the two bolts there should be some numbers stamped into one side of it. Some of the AEL's also have a L stamped on top of that flange. I would send it to Chad.
Fri, Apr 22, 2022 8:59 PM
catjoey18
Who is chad and how can I get ahold of him?
Fri, Apr 22, 2022 11:15 PM
kracked1
Reply to catjoey18:
[quote="catjoey18 post=237394 userid=2316"]Who is chad and how can I get ahold of him?
Look up a couple posts. Chad Enyart, ACMOC member
 [/quote]
Fri, Apr 22, 2022 11:27 PM
Thank you received: 24
Reply to kracked1:
 [/quote]
Chad's username is wyocat
Sat, Apr 23, 2022 12:21 AM
Looks like a Cat Thirty carb.
Sat, Apr 23, 2022 3:27 AM
kittyman1
unless you are totally into the original/restore thing, another small carb will work flawlessly....even if it is remotely close to spec..
-carbs are unbelievably forgiving and compensate even if 100 percent not correct for application..just another option etc..
Sat, Apr 23, 2022 2:14 PM
rax200
Reply to kittyman1:
Hi All,
Have a look in the Technical library for this doc it has all the carby there.
Caterpillar Accessory and Supply Catalog Form 1736 May 1944
Regards
Sat, Apr 23, 2022 6:06 PM
Earlcoate Charity Open Day
