R6 Info
Showing 1 to 10 of 13 results
SoCalCatMan
Send a private message to SoCalCatMan
Does anyone know anything about the elusive R6? What engine, what’s close in running gear? Is trying to Frankenstein one possible, or is that more work than it’s worth? [attachment=67428]8E4DEF60-F679-4718-9D80-2D9465336D38.jpeg[/attachment]
Tue, Apr 19, 2022 2:38 AM
Bruce P
Howdy.  So far as I can tell they were a 4/5R D6 chassis.  The engine was the G4600, which was the gasoline version of the D4600. A few of these engines were put into early No 12 graders under the 6M prefix.  I am very intent on building an R6, I have the chassis and thought I had a grader with an engine, right up until I didn’t.  I’ve spent quite a bit of time studying the 6M grader parts book, comparing numbers between the gas and Diesel engines.  I believe this is a very doable project once a suitable engine is found.
Bruce P.
Tue, Apr 19, 2022 4:18 AM
SoCalCatMan
Reply to Bruce P:
Bruce P.
Cool! Upon talking with my father. I found out that he has original paperwork for an R6. When he bought a Twenty two before I was even born for ten bucks, it came with a bunch of cat paperwork and amongst the pile was either a spec sheet or a parts book for one (also he said it’s not for sale lol). With that and the knowledge you gave me, hopefully finding what’s needed won’t be a large task. Good luck on yours!
Tue, Apr 19, 2022 4:58 AM
Bruce P
Reply to SoCalCatMan:
That’s cool that he’s got some literature!   I’d love a scanned copy of it, if that’s possible.
Bruce.
Tue, Apr 19, 2022 5:02 AM
SoCalCatMan
Reply to Bruce P:
Bruce.
I’ll be sure to post pictures! Not sure if it will be today, but I’ll definitely take photos of it when we get it out.
Tue, Apr 19, 2022 5:08 AM
Thank you received: 23
Bruce, do you think a pseudo-G4600 could be approximated if an original can't be found. I'm guessing outside of the head, manifolds, carb, and mag (latter two are probably not hard to come by if off-brand), maybe only the pistons are different? I'd wager a diesel head could be adapted with a spacer plate and spark plugs buried way down : )
Tue, Apr 19, 2022 6:39 AM
gauntjoh
Librarian
Reply to Bruce P:
Bruce.
[quote="Bruce P post=237333 userid=2447"]That’s cool that he’s got some literature!   I’d love a scanned copy of it, if that’s possible.
Bruce.  [/quote]
I would definitely add any scanned R6 documents to the club library. They would make a great addition.
Tue, Apr 19, 2022 7:13 AM
Bruce P
[quote="neil post=237335 userid=911"]Bruce, do you think a pseudo-G4600 could be approximated if an original can't be found. I'm guessing outside of the head, manifolds, carb, and mag (latter two are probably not hard to come by if off-brand), maybe only the pistons are different? I'd wager a diesel head could be adapted with a spacer plate and spark plugs buried way down : )
A guy could probably get one built.  The heads are altogether different, the accessory drive is different, the front cover is different because the governor lives in the front cover like a 4400, not in the fuel pump like it is in a D4600.  Of course the manifolds are totally different too.  It could be done I’m sure, just like anything, throw enough money at it and you can make it happen.
BP.
 [/quote]
Tue, Apr 19, 2022 8:44 AM
Reply to Bruce P:
BP.
 [/quote]
Ah, that's quite different isn't it.
Tue, Apr 19, 2022 7:37 PM
Bruce P
Yeah, the basic block is the same but the details are all different.  I’m really lucky to have a parts book from the gas grader.  It’s been invaluable in tracking down the details. I’ve spent several hours comparing numbers between the gas and diesel graders, and then from the graders to the 4600 in the D6.
If a parts book for a R6 were to surface, that would be the holy grail, as I still have some questions about the front cover area on the R6.
If anyone has a line on a gas No 12, or just the engine, I’m all ears.
BP.
Tue, Apr 19, 2022 9:17 PM
daron
Reply to Bruce P:
BP.
Bruce-
I think Tom Madden had/has one (#12). You might check with him,
I believe it was at GP's several years ago to try to get it running.
Daron
Tue, Apr 19, 2022 11:09 PM
