Off Topic - Removing sump oil through the dipstick tube ?
Showing 1 to 10 of 11 results
gauntjoh
Librarian
My son has a Sanderson Teleporter telehandler and it is really very hard to drain the engine sump when changing the oil due to the inaccessibility of the drain plug, and when you finally get it out, you get covered in oil..
I seem to recall a system to drain the engine oil by sucking it up a tube inserted in the dipstick tube, or maybe I was dreaming this.
Has anyone heard of such a system and has any experience of using one ?
Mon, Apr 18, 2022 2:01 AM
bursitis
yes i have one works great. mine is a john dow brand. they are called evacuator
https://johndow.com/product/20-gallon-fluid-evacuator/
Mon, Apr 18, 2022 2:20 AM
Fat Dan
Thanks bursitis :
Myself, I was looking for one more like this and didn't know or forgot what it was called.
1.7gal evacuator with hand pump
Mon, Apr 18, 2022 3:57 AM
Shaban1983
Send a private message to Shaban1983
Reply to Fat Dan:
Thanks bursitis :
The only downside with those systems is the sediment/whatever crap is on the bottom of the oil pan stays there. So its good to do a proper plug drain every now and then just to get rid of sediment
Mon, Apr 18, 2022 4:12 AM
bursitis
Reply to Shaban1983:
that was my opinion also until i used it for a few years.  if used properly it works just as good as the drain plug in most cases.
Mon, Apr 18, 2022 4:16 AM
bursitis
Reply to bursitis:
check out harbor freight-----https://www.harborfreight.com/search?q=oil%20extractor
D4Jim
Thank you received: 13
Reply to bursitis:
Harbor freight made a 12 v model years back and I have used it all the time when changing oil in the 4-wheelers (ATV) no mess no fuss; takes about 4 minutes to suck the oil out when warm which amounts to about 2 gal. If I was doing it on a large piece of equipment I would go with something like the JD which is one of the best made. Of course the size of the dip stick tube might limit how long it takes.
Cats Forever
Mon, Apr 18, 2022 5:56 AM
Thank you received: 34
Reply to D4Jim:
yes you can get them in 12volt or air operated workshop size units. many auto trans dont have a drain bung and its a messy job as you have to drop the pan. the BTR 95le auto trans made for australian ford vehicles didn't even have a dipstick for early 2000's production they soon fitted dip sticks to the next model. to change the trans oil you had to run the engine in neutral and pump in the required amount while the unit pumped out the old oil. cat actually use a similar set up on some industrial engines.
the mate had a incident with a air operated unit at work.
he forgot to de-pressurise it before opening the valve to drain the catch pan (this unit did suction as well as conventional drain bungs) and copped a bath in old oil it even sprayed the roof of the shed 6metres in the air. it was pressure empty to drain the tank. the valves were set "wrong" so he wore it. still lived at home so he rang his mum to bring him a changed of clothes. good thing they have shower facilities at work.
Mon, Apr 18, 2022 6:30 AM
Reply to trainzkid88:
its also possible to extend that drain to a better spot with pipe fittings and some tube i have done that on stationary engines.
Mon, Apr 18, 2022 6:33 AM
D4Jim
Our local Wally World went to evacuating the oil through the dip stick tube for oil changes rather than the drain as it lessened their liability of improperly tightened drain plugs.
Cats Forever
Mon, Apr 18, 2022 6:44 AM
gauntjoh
Librarian
Reply to D4Jim:
Thank you for all the information guys, it is really appreciated, I will pass it all on to my son.
Mon, Apr 18, 2022 9:29 AM
