Tool bar dozer
Tool bar dozer
Showing 1 to 7 of 7 results
Mschwartz
Purchased D4d, it is a 20j model and has what I believe to be a No 4 toolbar blade.  Is this a good blade?  Never seen another one in person so guessing not very common round here.  Does not look to be in bad shape. Does not appear to be easily removed for farming. What can you tell me from the pictures. Thanks, Mike  [attachment=67404]302665FF-9FD1-4143-87AF-85BC19B91885.jpeg[/attachment] [attachment=67403]FD93906B-C96A-4CF4-B5A6-406C70D4CCBC.jpeg[/attachment][attachment=67404]302665FF-9FD1-4143-87AF-85BC19B91885.jpeg[/attachment][attachment=67405]84F6C062-803B-496A-BCD8-E66BFC646913.jpeg[/attachment]
Fri, Apr 15, 2022 1:14 PM
Thank you received: 32
Yes, that is a number 4 blade set up. Easy to just remove the vertical pins, pop the hydraulic cylinders/hoses and set forward and block up push arms;back out and go farming.
Swapping from blade to toolbar one needs a good forklift or shop hoist to make life easier. No need to remove the track frame mounting plates/trunnions.
For what its worth, I was taught to have the trunnion caps backwards of how it is set up currently for pushing with the blade. It probably does not matter unless a clearance issue with grousers/tracks binding up with the braces.
Very handy to have around the farm.
Enjoy your new workhorse. Thanks for sharing the photos. JM
Fri, Apr 15, 2022 9:07 PM
Fat Dan
I like your D4d, Thanks for the pictures.
It looks like it would push snow really well. .
Fri, Apr 15, 2022 9:29 PM
sheddcanyon
Send a private message to sheddcanyon
Reply to Fat Dan:
Dan, is it true Alaskans have 100 different words for pushing snow?
And can any of them be repeated on a family-friendly forum?
Sat, Apr 16, 2022 12:33 AM
TomTrack44
Send a private message to TomTrack44
Reply to sheddcanyon:
Hi Mike, we have a D4C with same set up. Follow JM's instructions, go farming. Remember to block up the arms when you back out of it. Is very easy to do. Farmed with it for many many years.
Sat, Apr 16, 2022 2:41 AM
ChuckC
Send a private message to ChuckC
Reply to TomTrack44:
It is very easy to remove the blade like JM said. Once you have done it a few times it will take about 5 min. to remove the blade. I have one on my 5UD2 and remove it often when farming.
Sat, Apr 16, 2022 7:35 AM
17AFarmer
A no.4 and a no.6 toolbar —dozer was a beautiful setup we had one on a D6B and pulled an 8 row planter and furrowing bar with it plus dozing with it WISH I had it back 17afarmer Mike Thornton Wa.
Sat, Apr 16, 2022 7:39 AM
caterpillar13
Reply to 17AFarmer:
under carriage looks great
Sat, Apr 16, 2022 10:38 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
