eletric system
16 years 2 months ago #20497 by deereman
eletric system was created by deereman
Need a drawing for the charging system on a d4-7u. Gen will not charge the 6volt bat. Have taken regulator apart ,looks ok and brushes also ok. any ideas
tnks Doug
email <a href="This email address is being protected from spambots. You need JavaScript enabled to view it." target="_blank">This email address is being protected from spambots. You need JavaScript enabled to view it.
16 years 2 months ago #20498 by ccjersey
Replied by ccjersey on topic eletric system
sure your wiring is all in place?, no hanging wires etc? Battery disconnect switch closed (if it has one), good ground connnection on both ends of the battery ground cable.
Just for an initial check take a test light or volt meter and make sure you have battery voltage at the regulator BAT terminal with the engine stopped. Then polarize the generator by shorting between the BAT and GEN (or ARM(ature) it's sometimes called) terminals there on the regulator. You should get just a spark, that's a good sign and enough to polarize it.
You can check the generator by shorting the F(ield) terminal to ground with it running and it should go to maximum charge/voltage output. If not, there's something wrong inside the generator. You may need to have a volt meter there on the regulator BAT or the generator ARM terminal to see the voltage if your ammeter is burned out or stuck, regulator is bad, wires are broken etc.
16 years 2 months ago #20519 by Old Magnet
Replied by Old Magnet on topic eletric system
There are several wiring schemes to choose from.....maybe these will help:)
Time to create page: 0.129 seconds
