Cats Forever
Probably the seal that goes between the injection pump and the fuel tower. Very common for it to leak fuel into the crankcase. See upper right photo #2. Injection pump has to come off to replace it.
[attachment=67227]Injection Pump removal.JPG[/attachment]![]()
Thank you! Thought that might it, but needed confirmation from someone that knows. Thank you again!
Well I sure messed that up... Moderator, please delete my post. Thank You
pretty sure the oring is just a standard #8 oring. best confirm though
Uses a trade size -318 o-ring.
