- Thank you received: 20
Yup , did that before.Is the throttle opened or pulled back enough? Compression lever in run position?
The transfer pump puts out just a few pounds of pressure about like an auto, I'd guess, 5 to 8psi. A quick check you can use a temp gravity feed tank or an electric fuel pump that should be of pressure.How much pressure does the transfer pump.have to produce minimum to open the injectors. I had it running for about 5 seconds but it died and won't restart.
support@acmoc.org
- Chris R
- Jason N
