D7 17A clutch
D7 17A clutch
Showing 1 to 10 of 10 results
dd8hunt111
Send a private message to dd8hunt111
I thought someone might have some thoughts on what happened to
the clutch on my d7.I was pushing some small trees down in a fence
row when i got her a bit over loaded and got the tracks spinning.I did
this twice and on the third time it suddenly stoped.I tried it several
times after and it pushed great until i got the blade almost full, then
it just stoped.I noticed some oil mixed with water flying from the clutch
flywheel area.I drained the clutch oil and found one of the four pins
that secure the pressure plate and clutch in the oil pan but did not find
the spring or the broken piece from the pin.I thought the pin i found could have been left from a previous repair.Does this sound like the clutch
is working fine with one pin missing until it reaches a certain load or is this
just wishful thinking?I think the clutch needs to be removed in order
to replace the pin and oil seal!!!!!!
Any thought appreciated!!
Hunt
Sat, Sep 6, 2008 6:07 AM
can you see the output shaft/U-joints of the oil clutch on that tractor like you can on the 8U/9U D6? If you can see it, remove enough floor plates/open enough doors to watch it while you're pushing. You could have either the transmission or steering clutches slipping, but unfortunately, I expect you're right, it's the oil clutch, you just don't smell it since it's kept cool by the oil.
What kind of snap does the lever have when you engage the clutch?
Sat, Sep 6, 2008 7:01 AM
catman580
Send a private message to catman580
Have you adjusted the clutch since this happened . Did you replinish the clutch compartment with new oil . 😊
Sat, Sep 6, 2008 7:15 AM
Thank you received: 16
Reply to catman580:
The four sets of pins and springs don't drive the clutch, they just assist in releasing the clutch plates when disengaging the clutch. Not likely they are the cause. Oil flying around is normal but water isn't. Check your clutch adjustment.
These units wear very well, but there are limits....how many hours on the machine and when was the last time any clutch work was done. Vibration of the unit would also be an indicator that all is not right.
Sat, Sep 6, 2008 8:12 AM
dd8hunt111
Reply to catman580:
I have all the floor plates out and can see every thing moving,the right
steering clutch works very little to non at all,have not tried to adjust yet.
I adjusted the hand clutch trying to get the shaft to stop when disengaged
but the brake disc was worn out.Can you adjust the hand clutch to tight?
After i adjusted the hand clutch is when things started going south.I filled
the clutch with new oil but did not help.I have not tried to adjust the clutch
at all.I talked to a cat dealer and they said that the adjusting ring was most
likely frozen and would not be adjustable with out removing the clutch.
The lever has very little snap even after i adjusted.The system is very smooth
with little to no viberation.
The only adjustment was on the hand clutch lever.
Thanks for your response!!
hunt
Sat, Sep 6, 2008 8:49 AM
Reply to dd8hunt111:
hunt
Adjusting the clutch means rotating the adjusting ring that your Cat dealer mentioned. Changing the lever adjustment just moves the lever position.
Here is how to adjust the clutch:
Do not over tighten the adjustment lock clamp nuts as they have been known to strip and requires clutch tear down to repair.
Sat, Sep 6, 2008 9:25 AM
dd8hunt111
Thanks, Old magnet for the info on adjusting the clutch.
hunt
Sat, Sep 6, 2008 9:35 AM
Old 3T lover
hunt
Now back to the original problem(first problem). Your clutch stop brake may be worn out. To put tractor in gear, slow the engine to the lowest idle possible. Then if you have a CCU on the back, you can stop the transmission gears from turning by pulling 'up' on the winch lever until the blade stops rising. Or pump both of the steering clutch levers at the same time (with one arm) until you can't pull them anymore(or they get very difficult to pull).
Sun, Sep 7, 2008 12:10 AM
dd8hunt111
Reply to Old 3T lover:
Knowledge is priceless!!!
Thanks guys for the help on the clutch.It's working perfectly after draining
the oil, washing out with kerosene and filling up with fresh oil.The system
had more water than i thought,I had changed the oil a couple of weeks
ago but some how it still had a lot of water left,anyway it does not throw
oil and water out now and does not slip.I did adjust the clutch a small
amount , and will adjust properly when i find a spring scale,so a huge
thanks for your help.I had already called someone to remove the clutch.
I was very pleased to call and cancel.
Now for the next search for knowledge,does the weight of engine oil
(15-40 vs 30) have any effect on the performance of the govenor ?I changed
oil a couple of months ago and put rotella 15-40 in the engine and now
the govenor does not work.Most dealers sugest 15-40 now.
Thanks again
Hunt
Thu, Sep 11, 2008 11:59 PM
Thanks again
Hunt
No, 15W40 will not affect the performance of the governor and should not have any detrimental effect on the performance of the engine.
Have you checked that it has oil in it? It is filled along with the injection pump housing on most of the old tractors that don't have pressure lubed injection pumps.
What does it do or fail to do?
Fri, Sep 12, 2008 6:54 AM
dd8hunt111
the govenor would always kick in under load when the engine rpm would drop.
Now it does not kick in at all.
Fri, Sep 12, 2008 8:49 AM
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
