Cat d6 9u steering clutch bolts torque
2 years 8 months ago #236299 by mikewood869
Does anyone know what the bolt are torqued to on the bolts from the final drive and from the steering clutch to the rear end on a cat d6 9u or is it just feel tight?
2 years 8 months ago #236300 by Rome K/G
Standard grade 8 bolt torque.
2 years 8 months ago #236301 by mikewood869
100 foot pounds?
2 years 8 months ago #236302 by Rome K/G
3/8" bolts 32+- ft lbs
1/2" bolts 75+-10 ft lbs
5/8" bolts 150+-20 ft lbs
2 years 8 months ago #236303 by bruce oz
2 years 8 months ago - 2 years 8 months ago #236306 by Rome K/G
Pinion flange to steering clutch drum bolt torque?
Pinion bearing cage to case bolt torque?
Pinion to flange tons press fit?
Bull gear to to hub bolt torque?
Dead shaft nut torque?
Bearing/seal preload nut tightness?
Last edit: 2 years 8 months ago by Rome K/G.
The following user(s) said Thank You: bruce oz
2 years 8 months ago #236308 by bernie
 fastenal.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
2 years 8 months ago #236312 by mikewood869
I believe its the drum side and gear that have bolts that go in. The diagram that I'm looking at is on pg. 114. The article is D6 TRACTOR 9U13263-29764 FORM UE0032595 ue032595.
2 years 8 months ago #236314 by bruce oz
2 years 8 months ago #236315 by Rome K/G
For 6B5063 bolts use the fine thread bolt torque then turn more if needed to bend the locks properly.
Time to create page: 0.193 seconds
