D7E 48A550 fluid specifications
Showing 1 to 10 of 10 results
716thMP
Send a private message to 716thMP
Bought another Cat to go with my D73T and would like to know all the capacities and oil type. It is a D7E-48A550 cable with tilt blade 1962 model with turbo and 24 volt electric start.
 [attachment=66864]C0D20A7F-CE59-43B9-84BB-769344E012F3.jpeg[/attachment] [attachment=66864]C0D20A7F-CE59-43B9-84BB-769344E012F3.jpeg[/attachment] [attachment=66865]1778B770-BF80-42BB-B9F0-90AAD8D36FDB.jpeg[/attachment] [attachment=66865]1778B770-BF80-42BB-B9F0-90AAD8D36FDB.jpeg[/attachment]
Wed, Feb 16, 2022 3:46 AM
716thMP
Capacities and fluid type for power shift transmission, winch, finals, and lift pump. I will use 15-40 engine oil in engine. I have parts manual and shop but neither one has capacities.
Thank you for your assistance.
Wed, Feb 16, 2022 4:53 AM
Capacities,
 [attachment=66866]Cat D7E Capacities 001.jpg[/attachment]
Wed, Feb 16, 2022 5:38 AM
Capacities,
Sorry, thought you were in Australia, lol
Wed, Feb 16, 2022 5:39 AM
Thank you received: 54
Rome, there is a arrow mark on all scanners indicating the top right corner you know.
but its easy to do and most of us couldn't be bothered to be that pedantic.
as for oils contact the tech advice line of your chosen oil company they can help you with that info. as any in the owners book for oil type is outdated and in many cases has been superseeded. nothing says you cant use modern high performance mineral oils in these old girls. most of them will actually give better protection. the capacities are all still relevant of course.
Wed, Feb 16, 2022 6:02 AM
Reply to trainzkid88:
I would have had to fold the book in half, didnt want to do that, thought I could rotate pic after but couldnt.
Wed, Feb 16, 2022 6:35 AM
gary in CA
Thank you received: 11
 [attachment=66868]Cat D7E Capacities 001.jpg[/attachment]
Wed, Feb 16, 2022 7:21 AM
716thMP
Reply to 716thMP:
Thank you Gary. Gary is the transmission the same oil as the engine? And the final drives 80-90 oil?
Wed, Feb 16, 2022 9:52 PM
Reply to 716thMP:
No, use 30W Transmission/Drivetrain Oil, Cat has a good oil for use with the steering clutches, dont know if any other brands match.
Wed, Feb 16, 2022 10:14 PM
Cable Control holds 15 QT 50W gear oil.
Thu, Feb 17, 2022 3:48 AM
for you machine delo torqforce 30 and 50 are suitable for the trans and final drives respectively the oil clutch if fitted also takes 30 weight the torque force range has cat to-4 & to-4m approvals. can use torque force 10 in the hydraulics but in environment temps over 40 deg celcius must use engine oil or torqforce 30
delo gold 15w40 is suitable for the engine.(may have changed name)
the original delo oils were developed by standard oil co. for caterpillar. Diesel Engine Lubricating Oil
Thu, Feb 17, 2022 7:57 AM
| Kingaroy, Queensland
