Drawbar Studs and Nuts
2 years 9 months ago #235751 by Hank
Drawbar Studs and Nuts was created by Hank
I purchased a Drawbar for my 7U D4 and it did not come with any fasteners. I know the nut that holds the Drawbar to the dozer are 3/4" X 16 UNF thread, but I do not know what the stud (Part Number 3B1656) length and thread sizes are. Yes the stud will have 3/4" X 16 UNF threads on at least one end of it, but are the thread on the end of the stud that screws into the transmission housing the same size, or are they different? Also I need to know the length of the stud and if it has any portion of it that is not threaded. Thank you and as always Semper Fi.
Hank
2 years 9 months ago #235755 by rax200
Replied by rax200 on topic Drawbar Studs and Nuts
Hi hank,
You are after stud v155 and require 6 of them, you would of found them in your parts book under the transmission case.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
2 years 9 months ago #235756 by caterpillar13
why not just use grade 8 bolts
2 years 9 months ago #235759 by josh
Replied by josh on topic Drawbar Studs and Nuts
3B1656 stud, is 3/4" x 3-3/8" NF both ends.
2 years 9 months ago #235762 by Hank
Replied by Hank on topic Drawbar Studs and Nuts
Thank you for your replies and information.
2 years 9 months ago #235765 by rax200
Hi Hank,here is a screen shot of the cat website showing the size.
regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
2 years 9 months ago #235770 by Rome K/G
Replied by Rome K/G on topic Drawbar Studs and Nuts
0V0155 avail. from Cat, @ $16 each
2 years 9 months ago #235922 by trainzkid88
Replied by trainzkid88 on topic Drawbar Studs and Nuts
because bolts may strip or walk out of the housing studs will not. studs make for easier mounting too it much easier to lift a part into position over studs than it is to lift into place and then try and align bolts hence why many things such as clutches have dowel pins. for items like this its important to have the correct grade of fastners or bad things can happen.
either something breaks when it shouldnt or something doesnt break when it should and thus other parts are damaged.costing more time and money.
my grandfather drove a cane harvester for a farmer who was too stingy to remove the stumps from his field and he would plant right upto them so hitting one was a regular occurance,
sick of buying the slightly more expensive sheer bolts for the sheer points in the base cutter and feed screw drives he put normal bolt in instead. guess what the next time it hit a stump instead of a $50 fix and a couple hrs time it cost him hundredsof dollars and several hrs work becuase they had to replace driveshafts and other parts that where damaged and twisted becuase the bolts didnt snap cleanly.
it would have been cheaper to remove the stumps in the first place.
2 years 9 months ago #235998 by PhilC
Replied by PhilC on topic Drawbar Studs and Nuts
Dowel pins are for alignment purposes not for ease of fitting. Unless you have a fitted bolt there will be clearance around most bolts that can cause alignment issues so manufactures fit dowels to reduce misalignment. Other than automotive style clutches I can't think of any situation where the dowels make it easier to fit. Usually they are a tight fit.
I agree though that the original studs should be used rather than bolts as they have the correct thread depth for the application. They can help with fit-up but they can also be damaged when fitting too.
2 years 9 months ago #236006 by Hank
I was hunting on line for a Drawbar for my D4-7U and found one at Vander Haags. In fact they still have the whole D4 7U Bulldozer they are parting out, or can be purchased as a complete machine (Item 47RE001). The Drawbar was listed for $200.00 and $54.00 shipping from Wanamac, IN. to New Tripoli, PA.. I finally got everything from Vander Haags, the parts came in two different shipments, and I could not be happier with the condition of the Drawbar, Brackets, and Plate. I only got four of the fourteen studs, lock washers, and nuts that attach the Drawbar to the machine. The studs are in good shape, but the lock washers and nuts are well past their service life and I will be replacing them, as I would have anyway. The Stud is 3.25 inches long. The Stud's shaft is 0.750 diameter, with 0.750 X 16 UNF threads on each end of the Stud. There is a .875 inch long area in the middle of the studs shaft that is not threaded. The length of the threads on the end of the Stud that thread into the Brackets and the Transmission Housing is 1.125 inches long, and the length of the threads on the end of the Stud that the Nut and Lock Washer goes on is 1.250 inches long. Knowing what the Stud, Nut, and Lock Washer is going to be used for I would assume that they are at least a Grade 8 quality fasteners. Thanks to the members above there is a Part Number for the Studs, (0V0155). I just thought the information I am posting above could help someone down the road. Thank you and as always Semper Fi.
Time to create page: 0.195 seconds
