AIR start?
AIR start?
Showing 1 to 10 of 18 results
Iron Beaver
Send a private message to Iron Beaver
I saw the other day that the D315 engine had air start as an option. That is a thing I would love to add to my D315.
Anyone got any pointers? I think the D315 takes a Delco-remy 42MT starter, right? Is there a pneumatic version of that available? Barring that, could the bendix and nose of a 42MT be removed and retrofitted to an air motor? I've never worked with electric start on any heavy equipment so I could really use some expert input
Thanks!
Lewis
Mon, Jan 3, 2022 4:29 AM
Thank you received: 51
Hi, Iron Beaver.
Just as electric starters need batteries, so air starters need compressed air. do you have the facilities to supply compressed air to an air starter if you were to put one on your D315?
Mon, Jan 3, 2022 5:36 AM
Thank you received: 19
Hi, Iron Beaver.
More than just an air starter and compressor it takes a good sized air receiver (tank) as well.
The air starter drive is an inertia type, not lever/solenoid like a 42MT.
Mon, Jan 3, 2022 5:46 AM
PhilC
I've got an air starter on my 3304 that I will be replacing with electric when I fit the engine to my 955. Like OM says it needs a good supply of air to start the engine.
According to the parts manual for the engine the air starter was offered as an option from the factory.
Mon, Jan 3, 2022 6:17 AM
Thank you received: 24
Reply to PhilC:
I think the only challenging part would be to find the correct pinion gear for the air starter. Everything else is generic; tanks, valves, compressor options (engine-driven or remote), starter motor. You'd probably want some starting aid like a flamestart or coolant heater to assure easy starting. Bleeding the injection system could be fun! : )
Do it, and post pictures and video please.
Mon, Jan 3, 2022 7:09 AM
Hank
Send a private message to Hank
I worked on the assembly line at Mack Trucks for 3 years between 1999 to 2002. During that time I worked on the engine line installing starters on motors. There were various types of starters that went on various types of motors. From memory I would say I must have installed a air drive starter about once a week. I have also thought about a air starter on my D4 7U. What is the model number for the air starter that fits a D315 motor?
Mon, Jan 3, 2022 9:21 AM
Reply to Hank:
Cat # 3H3173 motor part of 2H1094 air starting motor group.
Mon, Jan 3, 2022 10:16 AM
Iron Beaver
Reply to Hank:
Good news! Airstartersdirect.com recommends this one for a D315 engine:
https://airstartersdirect.com/vane-air-starters/ss175gb03r31-02h/
Bad news! it's no longer made. This table: https://irtoolhelp.ingersollrand.com/hc/en-us/articles/360013919633--FAQ-SS100-Starter-List-of-non-current-starters-replaced-by-SS100 gives a cross-reference to two different part numbers, both of which appear not to exist.
Okay, I lied, they are listed on eBay from Radwell, for the modest price of more money than I have in the entire welder at this point.
This document: https://dalkos.ru/upload/documents/IngersollRand_SS175.pdf lists 300 SCFM use at max HP 90 PSI. I could probably muster 120 of those if I really put my mind to it. It would work for warm restarts if I had a biiiiig tank. I don't know if 15 CF is quite biiiiig enough. I might have to supplement with something like a Miller Big Blue Air-pak welder so I could get enough air to start my..... oh wait.
I also don't think it would take a full 18HP to start that engine. I still want to add air start because I love compressed air. But in all honesty if I found an electric starter first I might do that. In any case I would keep the pony motor, but I want something that can do a warm restart on the engine without the pony motor song and dance.
Mon, Jan 3, 2022 10:20 AM
Reply to Iron Beaver:
Hi, Iron Beaver.
Best-o-luck finding a place to mount a 15 CF - or bigger - air tank on your D315 engine without needing a small semi-trailer to haul it all around. There izza reason why Cat put pony motors on these engines. A goodly part of that is why they also now have engine oil pressure pre-start priming on some of their engines today. I do agree though that having the DE start for warm starts would be nice.
Mon, Jan 3, 2022 12:08 PM
D4Jim
Thank you received: 12
Hi, Iron Beaver.
Even an idiot like me can figure out how to use jumper cables. Finding another compressor etc when the normal starting tank has leaked down, not so easy. The last air start I saw on an engine was a Detroit in an antique Bucyrus some 50 years ago. All their equipment was junk.
Cats Forever
Mon, Jan 3, 2022 12:59 PM
Reply to D4Jim:
You don't need a huge tank per se. What you need is the engine to start promptly. That would work for a hot restart, but I'd question it for a cold start. The tank on Mack trucks from memory is probably about 20-30 gallons and cranking time, even cold, is about 2 seconds. So you'd use your pony to start cold and if you had no air in the tank. You could use the air start for a hot start. You could run a generic Bendix compressor on the D315 to recharge the tank just like trucks do.
Mon, Jan 3, 2022 7:53 PM
