D4 Oil cooler delete
2 years 11 months ago #234183 by 8C 361
D4 Oil cooler delete was created by 8C 361
On my recent auction purchase D4 7U 22xxx I drained oil and water out of steering clutch compartment, flushed with gas, changed oil and transmission fluid and got everything working good. The first time I put it to work the oil cooler started out to leak.
I have bypassed these before. I understand if this plug is removed, a spring and plunger can be removed and the inlet and outlet ports can be plugged. Matching the threads in the ports is always a problem, they are close to 3/4" not but are not tapered. I am afraid if tapered pipe plugs are used it could crack the casting.
I recall Old Magnet mentioned a source for proper plugs for these ports. Could you tell me where I could get them?
Thank you,
Tom Armstrong
2 years 11 months ago - 2 years 11 months ago #234186 by Rome K/G
Replied by Rome K/G on topic D4 Oil cooler delete
The plug is to drain the filter housing, the cap with two bolts contains the spring and plunger. The plugs and gaskets for the housing are 2-6B2731 Plug and 2-8B3410 Gasket, from Cat.
Last edit: 2 years 11 months ago by Rome K/G.
The following user(s) said Thank You: 8C 361
2 years 11 months ago #234190 by Old Magnet
Replied by Old Magnet on topic D4 Oil cooler delete
I use -10 size  0-ring face seal plugs (hydraulic fittings) which are a 1" - 14 tpi straight thread and  bit of sealer.
They only run a couple of bucks each.
Time to create page: 0.146 seconds
