D4 7U broken sprocket
2 years 11 months ago #233825 by EliG
D4 7U broken sprocket was created by EliG
New member here.   I just bought a D4 7U and am in the process of moving it home.  One issue that the machine has is that the right drive sprocket has the hub broken out of it.  Several of my friends that also have cats have never seen this before and I thought it was quite odd.  The machine was mostly used to clear paths through the timber to retrieve fire wood so we thought that maybe they pivoted into a stump and broke it.  This happened along time go and the details of the failure have been forgotten.   In trying to move it we discovered that all 10 of the lower rollers and the two top rollers are froze up solid.  Could that have contributed to the failure?  There is a whole story that goes with retrieving this machine that will share when I get it home.  Unfortunately I don't have any pictures yet.
Thanks!
2 years 11 months ago #233830 by RobertShaver
Replied by RobertShaver on topic D4 7U broken sprocket
this sounds like a fun post and i hope you follow through with lots of pictures and more info as you rescue this 7U. i would guess it broke the sprocket and there it sat till all the bottom rollers froze up. Pictures will help the great minds of this club guide you in the right direction to bringing the Cat back to life.
2 years 11 months ago #233834 by Old Magnet
Replied by Old Magnet on topic D4 7U broken sprocket
Depending on where and how it is broken there's a good chance it can be welded back together assuming it is worth saving.
2 years 11 months ago #233920 by EliG
Replied by EliG on topic D4 7U broken sprocket
I keep telling myself it is fun and I think things will go better when I get it home and I'm not working 200 miles away.
Old magnet thank's for the suggestion on welding. When the sprocket broke they limped it back home so I think it will be difficult to get things lined back up square to weld it up. I will keep everyone posted.
2 years 11 months ago #233924 by edb
Replied by edb on topic D4 7U broken sprocket
Speaking of welded sprockets here is a humdinger I saw last week--or how to keep this T4 Shovel running a bit longer.
2 years 11 months ago #233926 by Old Magnet
Wow!! and to think those welds are holding????
2 years 11 months ago #233927 by kittyman1
Replied by kittyman1 on topic D4 7U broken sprocket
agreed OM....wow.....how is that holding? must not be doing work of any kind?
- must be a parade Queen....no offence to Parade Queens
2 years 11 months ago #233936 by GrantJ
Replied by GrantJ on topic D4 7U broken sprocket
Eddie , that is a fine example of "The Fred Flintstone School Of Mechanics" . Those welds look even worse than mine. Elig, you might be better off finding a used sprocket. Just my 2 cents worth. Grant.
2 years 11 months ago #233947 by Ray54
Replied by Ray54 on topic D4 7U broken sprocket
To fit that fine mess they cut the track frame rather than removing it, it looks like. A bit better weld but still not something to brag about.
2 years 11 months ago #233961 by edb
the machine looks to be an incomplete early Trackson but could be some other brand unit as it has chain drive to the overhead winches. It has the loader frame bolted to the track frames in weak areas.
There are bodged repairs and additions every where.
The current owner said he may yet be resurrecting it enough to show its history of abuse and bush repairs.
