Thanks for that thought. An often overlooked item for the heart of things. Personal preference here is 12V on the 6V, never burnt one up (yet), but majority of ponies here start fairly easy, so no reason to be cranking away in excess. D4e's former 9U here used to run an 8V golf cart battery and the generator was bumped up to charge it fully. JM
I was told but have no way of checking for sure, Delco black labels are 6V, Delco red labels are 12V on all the Cat stuff of the 1950's. Both on starters and generators.
Careful what you polish the commutator with - can leave carbide imbedded in soft brass.
just for info. i use an optima 6volt battery and it cranks just as good as a 12 volt and the stock 6 volt generator keeps it topped up just fine. if needed extra you can mount two optima 6 volt battery in the same space as one 12 volt.
I have the same arrangement as bursitis. The 6v battery has never let me down. When I put the tractor back together, I did check over the starter motor and lubed everything, checked the commutator, replaced a bearing or two, and of course the belt.
