D6 5R engine weight?
Showing 1 to 7 of 7 results
hfdzl
D486?   4 1/4 bore 6 cylinder. weight with flywheel.  Rome KG?
Thanks, Herb
Sat, Nov 20, 2021 3:47 AM
1900-2000 lbs
Sat, Nov 20, 2021 6:34 AM
josh
Thank you received: 6
1900-2000 lbs
D486 automotive engine is 2120 lbs, does not include starting engine, and has a smaller flywheel and bellhousing, I would guess about 2500 total.
Sat, Nov 20, 2021 9:08 AM
hfdzl
Reply to josh:
Thanks everyone for your knowledge and sharing.
Sat, Nov 20, 2021 2:18 PM
PhilC
Reply to hfdzl:
The D6 5R has a D4600 engine. Weight is around 3100lbs.
Regards
Phil
Sat, Nov 20, 2021 2:43 PM
hfdzl
Reply to PhilC:
Regards
Phil
4600 has 4 1/4 bore, D318 has 4 1/2 bore?
Sat, Nov 20, 2021 11:26 PM
PhilC
Reply to PhilC:
Regards
Phil
I can't say about the D318 but the D4600 is the 4.25 inch bore.The D4600 was used in the D6 4R/5R and the D318 was used in the D6 8U/9U series.
Sun, Nov 21, 2021 2:10 AM
hfdzl
Reply to PhilC:
OK< THANKS< clears the smoke out of my head. Never could follow Cat engine number series. Why they were what they were.
Sun, Nov 21, 2021 4:56 AM
