5R D6 piston liners
5R D6 piston liners
hfdzl
Will later 4.5 bore engine liners fit into an earlier D6. D486? If they are not a direct fit  is there a a possibility for remachining?
Thanks, Herb
Wed, Nov 10, 2021 1:00 PM
PhilC
Part number for the 4.25" liner is 7B4348 and they are still available from Cat. Are you wanting to put 4.5 inch cylinders in a 4.25 inch engine?
Wed, Nov 10, 2021 5:49 PM
hfdzl
Reply to PhilC:
Hi Phil, No not really. Just was having a hard time finding anything aftermarket. That actually gave me size.
Thanks for the part #, that will help. Herb
Wed, Nov 10, 2021 11:17 PM
sheddcanyon
Send a private message to sheddcanyon
Reply to hfdzl:
I was able to source six after market 4.25" liners from Florin. However, I had to have a machine shop skim-cut the bottom o.d. because they fit too tight in the bore. So you might be better off paying Cat's price and be done with it. Buy once, cry once.
Wed, Nov 17, 2021 12:44 AM
hfdzl
Reply to sheddcanyon:
If I find the parts for any project, I usually buy them, even if I don't need them right now. I have a lathe , I can turn the OD if I have to.
THanks
Wed, Nov 17, 2021 2:08 AM
sheddcanyon
Reply to hfdzl:
THanks
Then I'd give Florin a try. It was a substantial savings, especially since you have to buy six.
Wed, Nov 17, 2021 2:48 AM
