Cat D315 Power unit, Gave it a workout today.
3 years 2 weeks ago #232796 by ag-mike
3 years 2 weeks ago #232803 by edb
Hi Mike,
it would appear there is some oil seepage out the cylinder head to cylinder block gasket joint on the main engine--you may consider doing a re-torque on the cylinder head fasteners--at the Dealer it was recommended to re-torque after fitting a new head gasket at around 50 and maybe 150 service hours of run time.
We always re-did them in the shop or field after the first start then again as described.
Reset the valve lash after re-torquing the head fasteners too.
We used to back of the fasteners one half of one flat and re-torque to spec. one fastener at a time and then keep going back over the lot without backing off until we got no further movement.
This D300 series of engines always wept oil and sometimes bubbles and water after the head has been disturbed hence the need to re-torque.
The following user(s) said Thank You: ag-mike
3 years 2 weeks ago - 3 years 2 weeks ago #232806 by trainzkid88
the same lincoln welder units were sold a tractor pto driven units in australia. being dc weld output they are brilliant welders. of course they were only a single unit not double coupled like that is.
Last edit: 3 years 2 weeks ago by trainzkid88.
3 years 2 weeks ago - 3 years 2 weeks ago #232812 by ag-mike
edb, I never had the head off. The diesel ran good enough when i got it. (less than 3000 hrs.)
Back "off" (right?) 1/2 of 1 flat. How do you see this??? Hot engine? Damn, it has a 10' hood!
Last edit: 3 years 2 weeks ago by ag-mike.
3 years 2 weeks ago #232814 by juiceman
Cool video and cooler welder! Hey, if I get one of these, will it make me a better welder? hahaha... Would trying to burn some carbon arc rods (air arc to some) put her under a real load? I think it is 275-300 amps recommended to do a good job of gouging material. That is a real nice unit sir. JM
3 years 2 weeks ago #232815 by TomTrack44
Great restoration, love the sound of the ole cat motor. I go out to the ranch every onece in a while just to start up the D6 9u to hear her purr! Locw discing or plowing in the fall too!
3 years 2 weeks ago #232818 by edb
Hi Mike,
we used to see such oil seepage, combustion bubbles under load and in extreme cases some water too from these engines and we would do the head re-torque and valve lash cold, run it and reset the valve lash hot finally.
