D4 Troubles, ohhh boy!
3 years 3 weeks ago #232613 by Rome K/G
Goes from bad to worse, ouch!!
3 years 3 weeks ago #232616 by d2gary
Replied by d2gary on topic D4 Troubles, ohhh boy!
Shut er down was the only good thing I saw on that video. Ouch
3 years 3 weeks ago - 3 years 3 weeks ago #232619 by D4Jim
Replied by D4Jim on topic D4 Troubles, ohhh boy!
Was that really Abbott and Costello???? Nice looking old 4030!
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Last edit: 3 years 3 weeks ago by D4Jim.
3 years 3 weeks ago #232622 by juiceman
Replied by juiceman on topic D4 Troubles, ohhh boy!
When in doubt, some whip the hammer out! I wonder if anyone would allow me to try freeing up their rack with my trusty "SledgoMatic".JM
3 years 3 weeks ago #232624 by Rome K/G
Replied by Rome K/G on topic D4 Troubles, ohhh boy!
Yea! I just shook my head, wow!
3 years 3 weeks ago #232629 by rax200
Replied by rax200 on topic D4 Troubles, ohhh boy!
Hi All,
You can see how well he maintains his tractors and machinery, if it brakes down and the maintainence mallet dode not work, just park it up and pull it apart.
Poor old girl, please save her
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
3 years 3 weeks ago #232637 by greengiant
Replied by greengiant on topic D4 Troubles, ohhh boy!
hmmm! it never occurred to me to take a hammer to my D4's rack! :) other than that, what is the best way to free it up? mine was sitting for 5 years ("running when parked") and starts good on ether but will not run on diesel despite the meter showing good fuel pressure, new fuel, new air filter. fuel oozes out the bleed points and injectors(doesn't squirt). so I'm assuming it's the rack. a "bigger hammer" or???
3 years 3 weeks ago #232648 by Rome K/G
Uh no hammer! remove the side plate from the pump housing and you will see the rack towards the top. Spray some rust cutter on it and let it soak, also the pump plungers can stick, spray some on them too. Then take a screw driver and lightly pry it back and forth.
3 years 3 weeks ago #232649 by GrantJ
Replied by GrantJ on topic D4 Troubles, ohhh boy!
I once started a D4 that had sat for a decade or more and it RAN AWAY, or so I thought. It was not smoking but screaming and no throttle control. I finally stopped it by cutting off the air. It turned out to be a stuck rack. I took a brass rod and lots of liquid wrench and GENTLY tapped the rack until I got it to move. It took a long time and lots of tapping to get it completely free, but it ran fine afterward. My point is BE GENTLE and it might work out. I think the brass rod rather than a steel rod is important. Good Luck with it. Grant.
The following user(s) said Thank You: juiceman, Fat Dan
3 years 3 weeks ago #232653 by greengiant
Thanks Rome and Grant, I was hoping it might be something like that. I was afraid to take the side plate off for fear something would fall out or the rack would get out of timing, but now I will do that.
