4A angle blade hinge
Richard~J~W
Send a private message to Richard~J~W
Can anyone advise why this blade hinge doesn't fit? there is no i.d. on the blade, but it is attached to a D4D
its 2J850 as per the parts book but the hole size is 1/8" undersize (measured on the pin, not the worn hole) and the height is about 3/8" too much.
Sun, Oct 24, 2021 9:16 PM
Looks like the one on the blade was bored out and a bigger pin was used. I believe the new bracket has been updated. The bracket on the blade will have to be removed and relocated.
Sun, Oct 24, 2021 10:29 PM
bursitis
pretty common in my woods to bore the hole bigger and install a new pin to fit. usually done to tighten up worn blades etc
Sun, Oct 24, 2021 10:39 PM
Reply to bursitis:
2J850 is the correct number.....so either the joint has been reworked or the replacement part is from the land of "almost right".
Sun, Oct 24, 2021 11:47 PM
Thank you received: 33
id say it has a bush mechanic fix written all over it. maybe the original broke or they made it take a larger pin instead of a proper repair.
Mon, Oct 25, 2021 3:30 PM
74A6C
Send a private message to 74A6C
Reply to trainzkid88:
I'd agree with trainzkid, looks to have been reworked. "Cut to fit and paint to match" type scenario. Maybe the ears were moved to accommodate the wear.
Wed, Oct 27, 2021 9:40 AM
Reply to 74A6C:
Being that the 4A blade uses four of those hinges, are they all the same on this unit?
Wed, Oct 27, 2021 10:48 PM
Richard~J~W
thank-you for all the replies....looks like i am gonna be busy with a half-round file 😊
O/M, they look the same part.....I hope so anyway as I ordered 4 pcs
Mon, Nov 1, 2021 2:33 AM
Reply to Richard~J~W:
I was referring to the ones on the blade now. Are they all the same? May be that is not a Cat blade.
Mon, Nov 1, 2021 6:41 AM
