D8 15A blade hydraulic cylinders and mounts
3 years 1 month ago #232349 by PhilC
Hello OM
I started undoing the bolts that would undo this morning and I noticed the flanges are different thickness so this is a custom job.
I can't find any rings or sleeves for this machine. None of the numbers work on Cat's parts website.
6H8626 compression ring
5H1508 compression ring
1H2709 oil ring
and the sleeve/liner
8B0375
Do you know if they have an updated part number?
Thanks again
Phil
3 years 1 month ago #232350 by Old Magnet
Plug those part numbers into a parts search at www.machinerytrader.com.
Those are still good numbers and they sometimes show the upgraded part numbers.
The following user(s) said Thank You: PhilC
3 years 1 month ago - 3 years 1 month ago #232390 by PhilC
Took a look through SIS and as near as I can find out the part numbers translate as follows
6H8626 = 3H4641 = 5M5704
5H1508 = 5M9053
1H2709 = 5M5697
The sleeve 8B0375 = 8N5676
Regards
Phil
Last edit: 3 years 1 month ago by PhilC.
Time to create page: 0.141 seconds
