D6 5R4217
D6 5R4217
Thank you received: 59
3 years 1 month ago - 3 years 1 month ago #231894
by hfdzl
Having saved this tractor from the torch, I would like to know how the steering clutch booster works. Does the tractor have to be moving under power? There is gear in the unit. Will the clutches release standing still?
Thanks, Herb
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Last edit: 3 years 1 month ago by
hfdzl.
Thank you received: 121
3 years 1 month ago #231895
by PhilC
Hello Herb
Like all these older machines anything behind the flywheel needs to have the clutch engaged for it to work including winches, pto units, CCU's and of course steering clutch boosters.
Otherwise it should disengage the steering clutch whether moving or stationary.
Regards
Phil
Thank you received: 344
3 years 1 month ago #231897
by edb
as said above the master clutch needs to be engaged for the Booster to work.
Without the engine running you can still manually disengage the steer clutches but, with out the boost feature, so it takes a moderate amount of effort to disengage said clutches.
Scans below may help.
hfdzl
3 years 1 month ago - 3 years 1 month ago #231907
by hfdzl
I would hope the clutches would would work, albeit stiffer. Good, the tractor will not run at present.
hfdzl.
3 years 1 month ago #231968
by PhilC
Sorry Herb I thought you were having issues with the booster but I assume you want to be able to disengage the clutches for towing?
3 years 1 month ago - 3 years 1 month ago #231969
by hfdzl
Hi Phil, hadn't thought of that, but would be handy. Usually tie the handles back. My first concern I think to find out if the tracks are free.
hfdzl.
D6 5R4217
Time to create page: 0.150 seconds
