D7-7M Cat pinion not engaging with engine flywheel
Showing 1 to 10 of 13 results
716thMP
Send a private message to 716thMP
I have rebuilt the flywheel clutch and the pony pinion sleeve. I have started putting it back together. I have clutch assembly installed and upper bell housing, adjusted clutch. And I am unable to connect pinion gear to diesel flywheel ring gear. The pony starts and the pinion sleeve spins but no lever movement more than 1". I tried accessing through inspection hole.Is there a way to get the pinion sleeve latches to release from the square nut inside the pinion sleeve?What would happen if I push start the CAT D7? Would the vibrations cause the pinion sleeve to release?
Sat, Sep 25, 2021 11:15 PM
Thank you received: 33
what is that 3rd pivot for?
have you connected every thing?
is something out of correct position check carefully that could be the issue.
when the main engine starts the opposite forces cause the latches to release. are they adjusted correctly if out of adjustment they wont work properly.
Sun, Sep 26, 2021 8:48 AM
Reply to trainzkid88:
Hi,
remove the pipe plug from the clutch cover and you will find the pinion latches below the plug opening--you may need to turn the pony with its crank handle to align one of the latches to the opening so you can view the latch operation---once engaged the latches do not release until the diesel starts. They can be released by pushing down on the screw adjuster end of one latch as they are geared together.
If the latches are not staying forwards after attempting to latch onto the two flat bolt head that holds the pinion sleeve on the shaft you may have the latches aligned to the flats causing it to have nothing to latch to--the latches have to NOT align with the flats to work as designed.
If the unit does not go forwards far enough to latch it could be the lock washer for the two flat head bolt is too large a diameter or one of the locking legs is fouling the sleeve.
These links to Toby's tutorials may help explain clearer---all pony pinions of the gay were so similar that the D2,4 etc are basically the same operation.
https://www.youtube.com/watch?v=lKI3wTZU4AA&t=23s
https://www.youtube.com/watch?v=vo0m1XBqdBY
Only other things to check are that the engaging lever pad inside is not unduly worn or that the wear button on the end of the pinion gear is in place--if they are at fault you may not get enough travel to engage the latches.
Can you engage the latches by hand or does the pinion sleeve advance forwards or is it locked--if locked the very short bolts that hold to pinion gear to its sleeve may be too long and are locking the pinion from moving forwards to engage the latches.
Hope this helps if not keep asking--let us know how you went please.
Sun, Sep 26, 2021 10:25 AM
716thMP
Reply to edb:
Hi,
When I rebuilt the pinion sleeve assembly; I used a brand new pinion gear from Cat. I did as the videos explained to testing it. I experienced problem when pinion gear got behind the flywheel gear but was able to get a heavy wire to pull it back. I believe the new pinion gear is having a hard time aligning with the the flywheel ring gear.
Sun, Sep 26, 2021 10:09 PM
Thank you received: 23
Reply to 716thMP:
I wonder if it's the correct gear?
Mon, Sep 27, 2021 8:39 AM
Sorry but I am having trouble visualizing your issue.
As a starting point this pinion engagement is done mechanically by the lever system that has nothing connected to it in your first picture above--these are not a centrifugally engaged pinion.
Scan below shows the controls.
Toby's RD6 Starting Sequence tutorial holds good for your D7.
https://www.youtube.com/watch?v=OiUL4UkERls
If this is missing your issue then keep supplying info until we get you past it.
In a pinch you may need to remove the Main clutch top cover and operate the pinion by hand as explained and get us some pictures of the issue if you can replicate it.
Mon, Sep 27, 2021 8:50 AM
716thMP
Reply to edb:
I disconnected lever system because I was only getting 1" movement in the lever that contacts the rear of the pinion sleeve. When I started the pony engine, I could see the pinion sleeve spinning. I feel the new pinion gear is not engaging with the flywheel ring gear because it is brand new. I am positive it is the right pinion gear, before I installed the upper bell housing; I tested the pinion sleeve to make sure it was working correctly. The pinion gear slipped past the ring gear on the flywheel and it took me 1/2 hr using number 9 wire to get it back to the proper position. I will try prying on the sleeve with screwdriver and if that does not work; I will push start the old Cat and see if vibrations from old girl will free the pinion sleeve.
But any and all suggestions are greatly appreciated. John
Mon, Sep 27, 2021 8:07 PM
716thMP
Reply to 716thMP:
These are pictures of my rebuilt pinion sleeve and pinion gear. John
Mon, Sep 27, 2021 10:25 PM
brian18a
Reply to 716thMP:
When you say pinion slid past ring gear, was that with sleeve attached to pinion? That should not be possible if it was. Were you able to get pinion and sleeve to engage ring gear and latch by hand before you put cover on? You say there was square nut on end of shaft, the latch plate would be screwed into end of shaft is a round disc with two flat sides. Also were the compression springs and a rod inside the shaft with rod sticking out through latch plate.. Without those, pinion would unlatch but would not positively disengage from ring gear
Pinion turning with pony running and and diesel not rotating means pinion is not engaged in ring gear and thus latches are not locked. If the pinion and sleeve moves at all, you should get gear grinding when you attempt to engage pinion, even if it did not engage..
If the original destruction of the pinion sleeve was by clutch failure that took out side of bell housing, the pinion shaft could be damaged. I have seen cases where clutch either bent or in one case broke shaft off.
Mon, Sep 27, 2021 10:41 PM
716thMP
What ever happen in its previous life destroyed lower bell housing. And the flywheel clutch looked like this prior to me rebuilding. All the links were destroyed, and yet the old girl still moved under its own power. Thank you John
Mon, Sep 27, 2021 11:41 PM
716thMP
This is what the upper bell housing looked like. I was able to get another upper bell housing from Jon and very much appreciated getting it. That is why the pony pinion linkage is not going to be the same. I do not know if that was a Caterpillar repair.
What would have caused so much damage in the first place?
I want to know if the pony engine transmission that the videos show; can be removed without pulling the pony engine? I want to keep the pony engine as it crank starts with two pulls.
Mon, Sep 27, 2021 11:59 PM
