Pony fuel bowl NLA?
Pony fuel bowl NLA?
Showing 1 to 10 of 17 results
8C 361
Thank you received: 5
I take it that the glass bowl is no longer available. I have emailed Dana with no response. My latest D4 still has original lines with shut off on left. I hate to tamper with it. I think I can plumb the line direct from tank with npt fittings. I have stand pipe with filter screen in tank. Tank becomes filter bowl right?
It has been so hot and no shade tree I have not been able to work on it. Now with fractured femur it will be a few days yet.
Tue, Sep 21, 2021 7:19 PM
Thank you received: 30
I believe the same bowl as fits the D6/318 engine should fit yours. A neighbor borrowed my spare and returned me a new one from Cat since covid arrived. They are not glass, but made of metal. I had my oldest of this type off this spring , could be 20 years already. Had bit of lite rust, nothing to bad.
Busy today but with check tonight hopefully if you need the parts nu off the new box.
Tue, Sep 21, 2021 9:40 PM
Reply to Ray54:
You can get a new bowl from Cat, it's just that it's steel. That's way easier than replumbing - about a 30 second change out
Wed, Sep 22, 2021 2:41 AM
Mike Meyer
I bought a glass bowl from Florin in July this year, 9B4514, it was $15
Wed, Sep 22, 2021 4:03 AM
rax200
Reply to Mike Meyer:
Hi 8C 361,
Have you tried to call Danna as I have brought some earlier this year from him, i just checked and they have 1335 in stock,
Regards
Wed, Sep 22, 2021 5:48 AM
Reply to rax200:
Hi 8C 361,
Regards
have seen them made from a suitable length of copper or steel tubing cut to length and a disc silver soldered to one end.
Wed, Sep 22, 2021 10:17 AM
8C 361
I got out my parts book to confirm glass bowl is 9 B 4514. I see D4 tractors before 7U 112262 were plumbed direct to tank with no filter bowl or shut off. They did have a screen in the lower control side shut off which was nice.
If the wife ever calms down I will try to get her to call Florin. I do not use phone due to hearing loss.
Tue, Sep 28, 2021 3:11 AM
restore49
Reply to 8C 361:
Have found old Medicine Bottles at Flee Markets that will fit.
Tue, Sep 28, 2021 4:13 AM
Busso20
Thank you received: 12
Reply to restore49:
Can I get some details to contact Florin and Danna for the fuel bowl and shut of assembly, my one is missing all together and has only copper line direct to carb. Thank you
Tue, Sep 28, 2021 9:40 AM
here is the Service Magazine from April 22 1952 that tells us of this change.
Tue, Sep 28, 2021 1:17 PM
Online
Thank you received: 120
Reply to Busso20:
That is the easiest way to contact him. Provide machine # and part # if you have it.
(916)-383-0317    I don't have his toll free number handy.
Good luck. JM
Tue, Sep 28, 2021 10:06 PM
