D6C Part Numbers
D6C Part Numbers
Thank you received: 16
3 years 2 months ago #231393
by Xtremist
Hey guys
I was wondering if someone who has a D6C parts book can give me a hand....I tried looking in the technical data section and found some of the numbers that i need but either couldnt find a few or couldnt make them out, and my parts book that i ordered is still 2 weeks out. My machine is has a 69j2622 serial number and is a powershift. Im after the following numbers
exhaust manifold gasket (8S8258 ?)
upper and lower gaskets and the oring for the supply and return oil lines for the turbo
all of the intake piping orings
studs, nuts and washers for the exhaust manifold (i think the nuts are 1B5355 ?)
the little steel backed orings where the lines connect to the injectors
gasket where the intake pipe from the turbo meets the intake manifold on the head (5S6735 ?)
the wiring harness for the glowplugs (5S8479 ?)
and the hood latch spring assemblies for the front of the hood on both sides
If anyone had a few minutes and wouldnt mind getting me some numbers id really really appreciate it !
Thank you received: 90
3 years 2 months ago #231394
by kittyman1
-exhaust manifold gasket, correct (6 required)
-exh manifold nut,correct
3 years 2 months ago #231401
by kittyman1
-upper turbo oil supply gasket 7h3270
-upper gasket return oil...1S4810
-lower 4F6109
-lower 4M6480
-o-ring in return drain tube 9H6067
3 years 2 months ago #231402
by kittyman1
-exhaust manifold washers 8M7145
-glow plug lead assembly, correct, 5S8479
3 years 2 months ago #231403
by kittyman1
not sure on injector line o-ring...6F1069 ??
3 years 2 months ago #231406
by Xtremist
that is awesome thank you very much for looking that stuff up ! did you have numbers for the manifold studs ? and is the square gasket number right for the intake pipe to manifold ? 5S6735 ?
3 years 2 months ago #231412
by kittyman1
exhaust manifold head studs, 3 listings....
-7S6719
2.80" long
-3M0496
2.60"
-8M1871
2.40"
3 years 2 months ago #231414
by kittyman1
gasket, intake pipe to intake manifold, correct, 5S6735
3 years 2 months ago #231421
by Xtremist
-lower 4F6109
-lower 4M6480
The 4F6109 and 4M6480 are those the intake piping orings ?
3 years 2 months ago #231434
by kittyman1
-those numbers are gaskets on turbocharger oil lines, 4F6109 + 4M6480, where it connects to oil supply, and one where it returns to engine block
-book says "gasket"
-o-ring in drain tube is 9H6067, correct
D6C Part Numbers
