Cat 922B Turbo
3 years 2 months ago #231357 by Dieselholic92
Cat 922B Turbo was created by Dieselholic92
Does anyone have a good used turbo for a 922B? Ziegler Cat, which had the ability to rebuild the injectors for my D6 2H, has absolutely nothing for parts and no way to rebuild it I was told. Am I better off trying to rebuild this one? I was thinking it would be more work than anything considering the condition of the exhaust housing.
Thirty Five gas, D4 5T, D6 2H, D6 9U, D7 17A, No. 12 70D, 12E, 12E, 922B, 922B
www.dandgexcavating.com
3 years 2 months ago #231373 by edb
Replied by edb on topic Cat 922B Turbo
Hi,
you may need to seek out a company that reconditions turbo's. At the Dealer we used a local company that did specialized work including turbo overhaul--we got hot end shaft seal ring grooves built up and re-machined, center housing bearing and seal ring bores re-sleeved and so it went on.
They may be able to set you up with a later replacement turbo with little modification needed --the turbo charge pressure is a fairly low pressure on these old girls from new likely around the low 20" of mercury pressure--10 to12 psi. I stand to be corrected as my old Rack Setting Book only has the 922A specs.
Hope this helps.
3 years 2 months ago #231399 by trainzkid88
Replied by trainzkid88 on topic Cat 922B Turbo
as edb has suggested contact a turbo rebuiling joint they may be able to help you. especially if the turbo was made by garret, holeset, or one of the other well known companies.
a lot of cat parts like bearings and fittings were made or supplied for cat by other companies
