Magneto Screws
Magneto Screws
Thank you received: 276
3 years 2 months ago #231221
by rax200
Hi All,
I am having trouble of getting out the screws (9F4959) that hold the coil in. Dose anyone have any tricks that might help.
Thanks for your help
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 236
3 years 2 months ago #231225
by d2gary
Sometimes if you put a screwdriver on the screw and tap on the screw it will help. A little heat from a propane torch might also help., a little heat.
Thank you received: 344
3 years 2 months ago #231231
by edb
maybe heat soak the unit in a very low oven at no more than 150F for an hour, carefully remove the unit and apply some bees wax or old time candle wax to the top of the screws, an impact style screw driver would be an asset in aiding removal--failing that I guess would be to carefully drill the screws out if not over hard--if too hard for a normal twist drill I have used suitably sharpened masonry drills to drill harder materials at the Dealer.
www.homedepot.com/p/TEKTON-1-2-in-Drive-...Piece-2910/205674680
Thank you received: 794
3 years 2 months ago #231266
try tightening them gently sometimes that can work.
try bolt off, chemsearch yield, loctite super penetrating oil
to apply heat try a high wattage soldering iron 80w or better.
thermal shock sprays can work too.
if you try the hammer tap or impact driver take up the slack first so you get a good force transfer.
3 years 2 months ago #231267
by rax200
Hi All,
Yes, I finally got the screws out it's only taken 2 days with a little heat, some tapping and a lot of patience.
Had to warm up the original anti seize then it came loose.
Thanks for your help.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
Magneto Screws
Time to create page: 0.141 seconds
